Ah, so THAT'S what the divisional sign on the muguard looks like, not covered by dirt and the rolls for unditching in 'lce Cold'
Yep, fairly decent shot of it here…no idea what the unit is though. Answers on a postcard…..Ah, so THAT'S what the divisional sign on the muguard looks like, not covered by dirt and the rolls for unditching in 'lce Cold'
I’ve got to make the unditching rolls and tow rope once I’ve finished the kit.
Cheers John.Progressing well Tim.
Many thanks Andrew. Glad you like it.Tim,
That's coming on beautifully. As you say those decals do bring it to life.
Like you I find new Airfix decals to be superb. Tamiya could take a lesson or three on that front!
Cheers Andrew. I don’t think they’ll be too hard to scratch up. Just wire and tape for the mats I think.Had a quick look Tim..... Couldn't find anything online either and even the usually reliable Scalemates doea not have any info....
https://www.scalemates.com/kits/airfix-a1375-austin-k2-y-ambulance--1325020
The Airfix decal schemes are set up as 5 ton for the desert, but 4 ton for Europe? They don’t have the film vehicle as an option. Restored vehicles show this as well, but they may be copying the film.I found one post on a forum showing the insignia and, with the usual internet rectitude, that it's the badge of the 9th Australian division, at Tobruk
Except it's NOT because , believe it or not, the 9th symbol is a platypus over a boomerang
Yes, really
I'm beginning to think it's a badge made up for the film.
BTW APPARENTLY also 'real' Katys had a 4 ton bridge disc, but Katy herself is 5 ton because of the 4X4 chassis
Not sure I believe that though. I mean, why have a weight 'correct' badge for a film? It's like you can't believe stuff you see online...
That's what I was beginning to think....I'm beginning to think it's a badge made up for the film.
Cheers Jim. Agree ref Airfix decals, possibly the best on the market at the moment. They are as good or better than Italeri, who’s are made by Cartograph I think.The decals have brought this to life. Always a relief when decals behave well. I've built a few of the newer Airfix 1/72 aeroplanes and the decals have been excellent.
Cheers Geoff, they certainly do….Looking fantastic Tim, as said the decal’s really bring it to life :thumb2:
Geoff.
Okay, now that is even more interesting. Most of the K2s I've seen pictures of in the desert show them from the side or the wrong angle to see the bridging disc. Maybe an extra ton is added for soft sand?The Airfix decal schemes are set up as 5 ton for the desert, but 4 ton for Europe? They don’t have the film vehicle as an option. Restored vehicles show this as well, but they may be copying the film.
Agreed, most of the images I have are from the side or the back…..apart from Katy of course.Okay, now that is even more interesting. Most of the K2s I've seen pictures of in the desert show them from the side or the wrong angle to see the bridging disc. Maybe an extra ton is added for soft sand?
I wish I could find the source again where I, long ago, came across a list of official bridge classifications for British vehicles, though.https://thinkdefence.wordpress.com/2011/12/09/uk-military-bridging-load-classification/ said:The elegant and simple solution they came up with was to invent a scale, or classification, related to weight but crucially, not only weight.
Each bridge type was allocated load class number and each vehicle was also given a load class number.
Instead of looking up and cross referencing a vehicle against a bridge classification a simple comparison of load class was performed, if the numbers matched or the vehicle was less than the bridge classification then it could pass.
A spacing of 80ft was assumed at the bridge classification took into account bending moment and other factors, it was not simply a weight (this is a key distinction)
Instead of weights of vehicles, each vehicle had a class, these starting at 3 and moving up to 24 in regular intervals.
If a vehicle’s load class was smaller than the bridges load class then it could cross and to assist with the rapid cross checking a standardised series of markings was designed, both bridge and vehicle had the marking in the same colours so a driver could simply compare the bridge sign with that painted on his vehicle and make the decision whether to cross without reference to bridge commanders or complex tables.
So the classification could actually change according to terrain then?The bridging class is not actual vehicle weight in tons, though.
