Tonys Airfix 1/72 spitfire mk1
yak face
Staff member
Heres my entry for colins BOB build . Its the ubiquitous Airfix 1-62 Spitfire mk1 starter set . Its a lovely looking kit and should build up with no bother . Heres the box and sprue shots, hopefully i can get a bit done this weekend FC661D07-059B-4099-80B5-13964838526D.jpegDA9789CE-4C07-47E0-9EEA-177E4A385E8B.jpegD5F5200E-7F8A-47B7-816E-92A816CF565F.jpeg52AD584F-0CB4-4AA3-A4A4-25344D519DAE.jpeg
Cheers Steve , it looks a very tidy bit of tooling , don’t think I’m going to attempt the supplied paints though , I’ve opened and stirred them and they look a bit see through !
Made a start on this , unsurprisingly with the cockpit! The kit supplies a decal for the IP , perfectly acceptable for a closed canopy , and i added some paper seat belts , cut off a sheet of paper instrument panels , theyre not sutton harness type but near enough and again the closed canopy will make them virtually invisible anyway . 47C729ED-938C-4453-AC4D-6AAEDDB82E1B.jpeg790DB1DD-64B9-45DC-968D-DA77BB987445.jpeg
Are you replacing the kit deflector sight? Tempted to get Khaden to replace his with a piece of clear film. Should look better than painting a part silver.
Yes well spotted karl ! Give that man a cigar ! I cut off the solid plastic gunsight glass and will be replacing it with a tiny bit of holographic confetti or clear plastic , cheers tony
Main airframe together now , just needing a smidge of filler on the top of the nose and a few smears of Vallejo acrylic putty in places. It’s now had a piece of clear plastic added for the gunsight glass ( just plain clear packaging , off a punnet of cherries I think ) and the canopy has been fitted . The canopy is crystal clear and a tight fit , just needing a bit shaving off the front of the cockpit aperture to allow it to fit .The exhausts ,propellor and wheels / undercarriage legs will be added after painting.Next job mask up the canopy and prime . 57671026-149D-481E-BB50-3A0251B4FD4E.jpeg9CABFBF7-BF32-46BD-963A-D6CF1102EB57.jpeg1D75D5DA-700D-447B-A78B-F0348E2519B0.jpegB75F385B-BD27-4844-B1BD-1D9E8B799211.jpeg
going to start mine in the next day or so, at least i can follow you to see what the pitfalls are
So far Paul the only things I’ve come up against are - the Fuselage locating pins were slightly off so the joint was a little stepped , sort it by either cutting them off or as I did just make the locating hole a bit bigger to give a bit of play . The canopy is a tight fit , the front edge of the windscreen has a lip which is supposed to go behind the front of the cockpit opening just above the instrument panel , I shaved a bit off the cockpit opening here and sanded a little off the back edge of the canopy . One other thing to watch out for is the plastic is VERY soft , even when removing from the sprue with cutters it can tear and cause unnecessary filling. Apart from these minor issues it’s making into a lovely looking kit , cheers tony
Canopy masked and sprayed interior green ,then after drying a nice coat of Halfords grey primer . This should show if theres anything that needs sorting , but its looking promising at the moment .71FCBAF1-8A23-4EC1-9E04-2148C4BC5AE0.jpegE1EA7F88-0B1A-45E8-94E0-49913B09E77B.jpeg
Got some colour on the underside tonight . I got a Hataka RAF set for this build and others in the future ( Airfix 1/24 hurricane for one !) I like these sets as they have all the specific colours you need for a particular scheme and ive found the hataka paints very nice to use. I dont use their thinners though ,I bought some a few years back and they went a bit weird , crystals forming on the bottom of the bottle ! I just use Vallejo airbrush thinners if i need to thin them slightly for airbrushing. 63E5F300-63CD-440D-8313-E56DC1E4A6B1.jpeg05A1DBB1-29E2-4FEF-AF1A-7CF54DA36386.jpeg
ive got the same hataka set, used it before and wasnt impressed but am going to give them another go
A 1:72 Spitfire, probably one of the fastest models you'll ever see. I like 1:72.
Well its been a while since ive had any time in the shed ,but today I managed to get some more paint on . I masked the underside and gave the whole upper surfaces a coat of dark earth a few weeks ago and today finally got round to masking the camo with blu tac and blasting on some dark green . The Hataka paints spray nicely and give a lovely sheen , coverage being very good with a couple of light coats . I know when these paints first came out they got a lot of stick for being very see through and other issues but I understand they addressed these problems and the newer formulations are great.The one thing i cant emphasise enough is to shake shake shake !! They have a ball bearing ( or something ) in them as an agitator and i find a minute on the paint shaker ,turning over halfway, Plus thirty seconds of up and down shaking by hand is usually enough to mix the pigment . I thin them if required with Vallejo airbrush thinners . B483FD3E-0E32-409F-8C7E-8175BE67CDC5.jpeg85458206-749B-4CD9-800A-D13B036AE266.jpeg
Mucker, that first photo looks quite disgusting.
Thank goodness I paint the easy way - Wiv a brush!
Now, here's a thing, and I really couldn't give a t*ss which is right, but your wing camouflage squiggles are the exact opposite to the one's I'm doing on my Hurricanes.
I've had a look on Google Images and both are used.
I'd be interested to know which pattern is the right one?
John Constable (Dec.)
Cheers matey ,it does look disgusting doesnt it :smiling5: , hopefully my ugly duckling will turn into a swan . I think that the camo was used in both versions ,with the green and brown reversed , as for if its right , Ive no idea ,I just followed the nice picture on the back of the box .
Regards B . Lutac
