Using CA accelerator
BattleshipBob
Cardiff
Evening
Just bought CA accelerator, i understand you put CA on one side and Accel or other and hypresto! But can you apply it with a cocktail stick etc and I assume equal amount to CA??
Sorry to wake some chaps up
Bob
Evening
Bob
Bob have a mask on when usein the acelrator as its not very nice stuff
i use a little brush to swab some acell on one part.......toothpick for ca on the other
Dont do what i did bob and use a cotton bud soaked in the accelorator - it did the trick but i ended up with a load of cotton fluff stuck to the part too!!
Thanks Chris, not opened it yet!
Excellent, will try!
Lovely a fluffy StuG, lol!!
Bob I put the CA on the model or part to be stuck, line it up , and then a quick gentle burst of the spray. I've tried it in a lid and used an old paint brush as well , didn't think much to that. Might have been better using a needle or piece of wire just to take a drop.
Thanks John, does the accelerator leave residue, if so hows it removed?
Bob
Only Bob if you use too much, then I've noticed a white bloom on the CA, normally happens when you get a bit excited and get to much CA on the model.:nerd:
Never bothered about removing it, the paint covers it ok. Its never that much anyway.
Thanks John, bank of dunlop chq in the post;)
Seem to remember someone saying you can get the accelerator in a bottle and not have bother with the spray.
Any idea where to buy it ?
ANDREW do they do one with a pointed tip ?
chris
Hi Chris
The short answer is I don't know, sorry.
This particular set is aimed at the the DIY and came with three bottles of their standard super glue, eg....
https://www.amazon.co.uk/dp/B00PKGYQMW/ref=cm_sw_r_cp_apa_fabc_RJVS1Q1Q1JY1XGS7T7D1
I'm on my second set of the super glue but the pen from the first set still works. I apply the super glue to the kit and then wipe the piece across the pen tip, applying the accelerator that way.
Sorry I can't of more help but you might find one online somewhere with a quick search.
ATB.
Hi Chris
ATB.
CHEERS Andrew for your reply an yes i'll have a look around
chris
Never used this myself, but would it be possible to decant some into a jar from the spraycan and dispense it from there?
thats what i do........cos it evaporates so quickly, i just squirt a little in the cans lid, use a small brush to apply it the stick the bit with ca on to it
Thanks Paul. I have had a bit of a read around about CA accelerators and am going to try Tamiya X-20A thinners. Accelerator seems to be mostly water with acetone as a fast dryer and deacidifier. X-20A is Isopropyl alcohol in water so may well do the same job.....albeit slightly slower.
