What grit sandpapers set to use for sanding aircraft model before airbrushing the primer on?
There are some parts in my SU-27 1/32 Trumpeter kit that are glued, and I would like to sand them before airbrushing the primer.
I know I need to use different grits, which ones?
After putting the coat of primer, what grit do I use for light sanding it?
Thank you!
Thank you!
