- Joined
- Apr 27, 2018
- Messages
- 15,027
jakko, the great detail continues. As to the copper wire try heating it to bright red then quenching in water this should anneal it and make it easier to work.
Looking great,Jakko.I added some straps to a few of the tie-downs:
These are just 0.1 mm plastic card cut into strips of random length, then folded, scrunched up and otherwise mishandled before glueing into position.
And all the main parts posed on the base I made earlier:
Missing is the trim vane, which should sit on the bow. Someone promised he would mail me one, but hasn’t so far :sad: Anyway, next, I sprayed Vallejo white primer from a rattle can onto all the parts:
This needs a second coat tomorrow, because some of the pencil lines still show through. Then the real fun begins, because I need to decide which colours the interior actually was after the explosion that blew the whole thing apart. I can’t figure out what exactly is visible in the photo of the real vehicle: why are the lower hull sides light in colour, but the upper sides and floor, dark?
The interior of these M113s was painted white (the more familiar green finish came once the M113A1 was already in production), so are the light areas white paint, or perhaps bare aluminium, or even aluminium oxide resulting from a fire? Are the dark bits on the interior scorched paint? If not, what else might have caused them to be that dark? Speculation would be appreciated :smiling3:
ThanksLooking great,Jakko.
I wouldn’t use the word “enjoyable” …I'm preparing a scratch-built project of my own with limited information and I feel your pain. But it's also very enjoyable searching out every last little anomaly.
I’m notLooking forward to the paint
PM me your address and i will send one i have in sparesMissing is the trim vane, which should sit on the bow. Someone promised he would mail me one, but hasn’t so far
That does sound like a plausible theory … let’s see if I can shoot holes in itmy guess is that before exploding, the M113 interior was engulfed by the thick and greasy smoke
Thanks, and starting is actually the easy bit, I must say in retrospect. The hull is simple, it’s all those little details you only discover once you’ve gotten somewhere that make this difficult.Looking very good Jakko. Wouldn't know where to start with this sort of thing.
Thank youWOW!...Such dedication! Absolutely mind boggling attention to and fabrication of such minute detail is....I can't find the words.
Thanks for the offer, but someone else supplied me with one today alreadyPM me your address and i will send one i have in spares
