Latest Acquisitions (2021)
  • Mark1
    • Apr 2021
    • 4156
    #361
    This has got to be the last one for the stash for a while :rolling::tongue-out3:Click image for larger version
    • Mini Me
      • Jun 2018
      • 10711
      #362
      A likely story.......but I won't hold you to it Mark. :smiling3: Rick H.
      • Lee Drennen
        • 7738
        #363
        Originally posted by GerryW
        Just ordered a couple of things, not sure if I'll have much use for them, but cheap enough to sit and do nothing.
        [ATTACH=CONFIG]n1150274[/ATTACH]
        And a double of
        [ATTACH=CONFIG]n1150275[/ATTACH]
        Those pin vice drills are nice
        • Lee Drennen
          • 7738
          #364
          Got this the other day Click image for larger version
          • AlanG
            • 6296
            #365
            That moment when you open evilbay just for a quick glance before the F1 starts and you find a model kit you've been after for years going for a price well under the 'normal' asking prices. Well it's just happened. I had clicked the buy-it-now icon before i even knew what i was doing. Slightly chuffed here.
            • The Smythe Meister
              • Jan 2019
              • 6248
              #366
              Originally posted by Mark1
              This has got to be the last one for the stash for a while :rolling::tongue-out3:[ATTACH]422525[/ATTACH]
              Hi Mark,
              That`s a cracking kit isn`t it?.... I bought one myself a short while ago,to replace a truck that i`d dropped,in my ongoing "Tonight,Long Stick Goes Boom" Dio....
              I haven`t started it yet,but after looking at the sprues,i`m expecting good things:thumb2:,
              Are you going to blog your build..... I,for one,will follow along if so!
              Andy
              • Mark1
                • Apr 2021
                • 4156
                #367
                Hi Mark,
                Andy
                yeah I might do,got some other stuff to finish first, then see if I can make my mind up what to pull out the stash next lol
                • Mark1
                  • Apr 2021
                  • 4156
                  #368
                  Found this in wilco, tow cables maybe.
                  £1.50 and can hold a bend.Click image for larger version
ID:	1150703Click image for larger version
                    Good value, but you might have a bit of a job cutting through it!
                    • Mark1
                      • Apr 2021
                      • 4156
                      #370
                      Got an abundance of tools at work :thumb2: a hacksaw will do if you got a little vice to hold it.
                        I was thinking of all those occasions I’ve tried to use wire cutters and ended up with a Frankenstein frayed end!
                        • GerryW
                          • Feb 2021
                          • 1757
                          #372
                          Sidecutters - good quality ones will do the job, no problems, used to make all my own motorcycle cables when riding my custom bikes
                          • Airborne01
                            • Mar 2021
                            • 4297
                            • Steve
                            • Essex
                            #373
                            Dremel mini-disc cutter - never fails, never frays - patience is a virtue though!
                              You beat me to it. This is the best way I found to cut steel wire cable, everything else frayed the ends. (I gave up on using steel cable for tow cables on models, though.)
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #375
                                It's a snap with a pair of cable cutters and no frayed ends.....available from Micro Tool. Also good for cutting piano wire and other hard or too thick items for regular side cutters. Rick H.
