Latest Acquisitions (2023)
    • 19106
    Just saw that on there as well Tim .
    Really ought to try it out .
    They also do half litres of MEK for the same price. That’s Mekpak to those with long memories. Used with a fine nylon brush it’s as good or better than TET, especially on plastic card and suchlike….used to be sold by Slaters in small bottles…...and unless you leave the lid off that much will last forever. Not as hot as Butanone, which can be used on ABS as well as styrene….
    • adt70hk
      • Sep 2019
      • 10542
      #1247
      Hi Andrew
      It is available from Amazon. It is obviously sourced abroad, but being Amazon should be priced at what you see.
      Have also seen it on eBay too, just a bit wary in case the nature of the contents cause an issue. but will give it a whirl!
      Go on John!!
      The cleaner is 5.13p per ml incl. P&P (here - used them before numerous times), the glue was 11.25p
        Go on John!!
        At that price difference it's well worth trying. Couldn't open that link by the way Andrew.
        • adt70hk
          • Sep 2019
          • 10542
          #1249
          PM on its way!
          • stillp
            • 8291
            • Pete
            • Rugby
            #1250
            Go on John!!
            Link worked for me - how much is their shipping though?
            • adt70hk
              • Sep 2019
              • 10542
              #1251
              Says in the shop....but that per ml price I quoted included shipping
                • 18302
                Ian,
                I don't think we can get the cleaner her in the UK otherwise I would have gone down that route....at least I couldn't find it last time I looked...it always has to come from somewhere in Europe and I'm worried about what will happen when it gets to customs given the nature of the contents but I might give it a whirl next time.
                That makes no sense at all it is exactly the same as The Extra thin Maybe John can get some in if you ask him. He would sell it as quick as he could put in the shop.
                  • 19106
                  Probably the same reason we can’t easily get Tamiya filler Ian….
                  • BattleshipBob
                    • 6869
                    • Bob
                    • Cardiff
                    #1254
                    Early delivery from Amazon
                    Very light and easy to hold, impressed
                    For my expanding Naval library
                    Both very interesting read, sad I know, all I need now is a job designing battleships, any going??
                    Used but like new £5.20 free p an p
                    This one good condition £7.50 again free p an p
                    • adt70hk
                      • Sep 2019
                      • 10542
                      #1255
                      SeeEarly delivery from Amazon
                      [ATTACH=CONFIG]n1205565[/ATTACH]
                      [ATTACH=CONFIG]n1205566[/ATTACH]
                      [ATTACH=CONFIG]n1205567[/ATTACH]
                      They're just StuGs that float.... You do know that don't you?!?! :smiling5:
                      • The Smythe Meister
                        • Jan 2019
                        • 6248
                        #1256
                        .... Also Bob,it does mean you'll actually have to BUILD SOMETHING !!
                        ..... Don't wanna scare you,but that's what we do, !!
                        • BattleshipBob
                          • 6869
                          • Bob
                          • Cardiff
                          #1257
                          Oh yes forgot lol
                          Cheeky, but trying my best under horrible circumstances
                          • BattleshipBob
                            • 6869
                            • Bob
                            • Cardiff
                            #1258
                            In addition, Will try my best to finish one meister, but holding my mum's hand in hospital sadly has priority
                            Bob
                            • Steve Brodie
                              • Sep 2014
                              • 4652
                              #1259
                              Sphere Products Transit Case Box C , external dimensions 34cm on all sides and 30cm internal dimensions, with a clear acrylic front, so the figures/busts have a view of where they are going :smiling5: :smiling5: , steel handle, and the bottom slides out, so easy to add and remove things. . Its quite heavy, so should keep everything safe, think I will stain it.Click image for larger version
                              Put this in the wrong forum :sad:
                              • adt70hk
                                • Sep 2019
                                • 10542
                                #1260
                                Originally posted by Steve Brodie
                                Sphere Products Transit Case Box C , external dimensions 34cm on all sides and 30cm internal dimensions, with a clear acrylic front, so the figures/busts have a view of where they are going :smiling5: :smiling5: , steel handle, and the bottom slides out, so easy to add and remove things. . Its quite heavy, so should keep everything safe, think I will stain it.[ATTACH=CONFIG]n1205578[/ATTACH]
                                Isn't that nice that they get to see where they are going!!
