All is beautifully executed. Would have thought the crane at 3 o'clock w/engine on hook being administered by crew. Isn't that where U started?
Yes mate that was the plan but the crane hung over the edge of the base to much so the engine would have been off the base as well. It's my fault I didn't plan it out properly.
I looked at that as well unfortunately All the cables have been glued and I would cause to much damage if I try and move it. It was my fault I should have given it more thought in the beginning because that was the original plan to have the engine suspended.
Very nearly there. I have added the Miniart Maybach engine. I left a few bits off so they could be on the workbench. There are a couple of figures with the engine but I will have a look through my figures to see what I have.
