Italeri Hudson Mk IV 1/72 scale.
rtfoe
Shah Alam, Malaysia
Hi,
Another commission build that I have started. I don't often do commission builds but was made an offer I could not refuse. Besides I had the kit in my stash and thought it was the only way I would ever build it. I got it years ago practically nearly free.
The kit
Fit isn't too bad where dry fitting before hand avoided any problems. Parts had minor flash and molding misalignment that was easily fixed. The only niggling thing was the destruction sheet doesn't show exactly where to attach the parts with arrows pointing right in the middle of the raised locating line so you won't know if it's before or after the line.
I will finish this in the markings of the RAAF Hudson used in the Malayan campaign. They were one of the first to encounter Japanese and shot down an hour before the first bombs dropped on Pearl Harbour.
Here's the usual sprue shot in the box...
filedata/fetch?filedataid=246965
wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
...after a coat of interior green.
filedata/fetch?filedataid=245990
Apologise if they are not arranged nicely.
I decided to glue the interior in place and then weather later as most of it will be unseen when the fuselage halves are glued together.
filedata/fetch?filedataid=246964
I didn't even bother to repaint the trimmed tabs...
filedata/fetch?filedataid=246963
​ I test dry fitted the glazed nose halves to the fuselage and they will need only a little filler and sanding.
filedata/fetch?filedataid=246962
They will go into the small tub of Future next.
That's all.
Wabble
Sounds great Wabble.Watching with interest.
Sounds good richard , i love a nice RAAF scheme
Didn't the pictures get through?
Did you get the pictures?
It would be the same as the RAF scheme of dark earth and dark green but with a silver under belly.
Reposting the missing images...
Click image for larger version  Name:	IMG_20250128_143105.jpg Views:	1 Size:	270.2 KB ID:	1247676 Click image for larger version  Name:	IMG_20241231_213306.jpg Views:	1 Size:	425.7 KB ID:	1247677 Click image for larger version  Name:	IMG_20250128_143105.jpg Views:	1 Size:	270.2 KB ID:	1247676 Click image for larger version  Name:	IMG_20250128_143105.jpg Views:	1 Size:	270.2 KB ID:	1247676 Click image for larger version  Name:	IMG_20250128_143105.jpg Views:	1 Size:	270.2 KB ID:	1247676
Looking forward to you working your magic on the Hudson, Richard. Your choice of scheme will be interesting.
I’ve got this one in the stash so will be looking watching your build with interest Richard 🧐👍
Geoff.
Always good to follow your builds. Looks a nice cockpit but as is usual little will be seen.
Hi I'm back, apologise for the long disappearance. Other builds got in the way and hit with a rather loss of mojo. One of the reasons that put me off this build were the rows of windows and I procrastinated until I sat down one night and just fitted them.
So here is where I left of ...Painted the engines and highlighted with aluminum. Dunked the clear parts in Future and let dry.
The kit supplied a separate rear door so I did what I usually do with my itchy fingers and cut out the existing engraved door, thinned the sides and added a lip. The opened door exposed ejector pin marks on the opposite of the interior. Filing down solved that problem...
1000159845.jpg 1000159860.jpg 1000160572.jpg 1000160845.jpg 1000161464.jpg 1000161497.jpg 1000161495.jpg
More on the next post.
Wabble
Welcome back Wabble.Great to see you creating again Richard.Nice to see a Hudson.
Rich
Nice to see this back on the bench. Moulded door looks to have been neatly removed. Ejector mark were a nuisance but well fixed.
Nice to see this one back on the go Richard.
Nick
Rich
Good to be back Rich...not many Hudsons being built so it is nice for a change.
Wabble
Hi Jim and Nick, yep, it was long overdue and had to be built. Opening the door was fun to make. Haven't used the drill for a while.
Wabble
