Italeri Hudson Mk IV 1/72 scale.
Hi, continuation of the build. I made a boo boo by drilling out the Astrodome hole then finding out the version I was doing doesn't have one. A little strip and putty will fix that...
Then I painted detail to the cockpit seats...
And weathered the seatbelts.
Next I glued the fuselage halves...
And sanded down the joints.
More later...
Wabble
Hi Guys, more work on the Hudson...
Painted up the IP and stuck it in...
Sanded down the turret fairing assembly...some dinks and gaps need puttying.
Got the wing halves cemented and used tape to hold them together at the leading edge to align and not have a step...saves sanding and cleaning up.
Wabble
Hate assembling the wings with the undercarriage pre attached as you need to guess the alignment and dehydral to get it to look right.
Click image for larger version  Name:	1000167656.jpg Views:	0 Size:	323.2 KB ID:	1273025
Okay I got that solved...
Click image for larger version  Name:	1000167656.jpg Views:	0 Size:	323.2 KB ID:	1273025 Click image for larger version  Name:	1000167656.jpg Views:	0 Size:	323.2 KB ID:	1273025 Click image for larger version  Name:	1000167656.jpg Views:	0 Size:	323.2 KB ID:	1273025
The engine nacelles were a bitch to fit with no locating pins or marks so I winged it. I did saw the nacele flaps as the engraved lines were too soft. This kit is tuff...heard it's not an original Italeri kit but a rebox of another brand.
Wabble
Good progress. Everything is looking very good. The hole you drilled but shouldn't have - even a modeller of you calibre make mistakes. Makes us lesser mortals feel better 😄
Well it might be a bit of a struggle, but it's certainly getting there. Well done Richard.
Nick
Thanks Richard, Jim, Joe and Nick...apologise for the late reply. It's taking shape even with struggles and mistakes. This makes building fun and challenging at the same time.
More progress...
Click image for larger version  Name:	1000174176.jpg Views:	0 Size:	285.2 KB ID:	1273937
This time its putty filling. I use Magic Sculpt two part putty for this process.
Click image for larger version  Name:	1000174178.jpg Views:	0 Size:	279.9 KB ID:	1273938 Click image for larger version  Name:	1000174177.jpg Views:	0 Size:	306.3 KB ID:	1273942 Click image for larger version  Name:	1000174177.jpg Views:	0 Size:	306.3 KB ID:	1273942
This putty helps with huge steps filling for misaligned fuselage halves. Doesn't shrink either.
Next up is sanding so I left it to cure within the hour.
Wabble
Happy new year Wabble. Nice work, a question if I may what filler do you use?
Happy New Year to you too Paul, I use Magic Sculpt which is not the usual plastic putty that everyone uses because I hate the shrinkage that happens and will need constant application and sanding. Two part putty like Magic Sculpt doesn't shrink and smoothens with water. Latest trick is using TET with a soft brush to blend the edges... compliments of Calvin Tan. Works best on figure joints...for planes I prefer sanding.
Wabble
Making progress. Interesting ideas for filler. I agree that when fillers shrink and need another filling it's just so time consumming,
And me being so slow I need quick fixes to move on.😂
Wabble
Therapeutic sanding... tralalalala...
Looks like a lot of detail needs repairing after the sanding process.
Lots of gunk collecting in the crevices and what nots...
That's all for now...the transparencies need attention next having not fitted flush and leaving horrendous gaps to be filled.
Wabble
Looking good Richard. Good to see you posting again. I seem to have completely missed this….or my memory is shot….not sure which 😁. Anyway, interesting use of magic sculpt. Only ever seen that used with figures before. I have some I have never used, but assume it’s a bit like milliput?
