Latest Acquisitions (2026)
Also very good ship cradle for 1/700 & 1/350. Revolves on the base and tilts.
Cool, where did you get that from? I have my Airfix German E-Boat to build and something like that would be great for it.
Its juts under 50cm long so would need to be bit smaller than that....
Hi
Do a search for 'sen model studio", in the menu look for 3D printed parts.
Beware I had a customs charge
Hope this helps
Got myself a small ship/boat holder/stand, as I have my new Airfix German Eboat to build in the not to distant future, and I don't really have a good stand, so I thought why not? It's a cheap and chearful one off Amazon, I thought is was coming from Amazon in the UK, but it did appear to come directly form China, looks like its 3D printed, and the adjustable butterfly type bolts/nuts look a bit small and flimsy, but I can always drill bigger holes and use larger ones if they give out.
Has a fair bit of adjustability, for space between each stand, and the width of the two end supports and the angle they can be tilted, so it should do the job. Obviously it would not be suitable for larger boats/ships.
Comes with thin rubber strip which you cut to size and stick on yourself....
