Joe's Airfix 1/48 Spitfire Mk1
Glad you got it sorted Joe , looking lovely now , cheers tony
Got the decals applied, still settling under softener. I need to paint the gun patches as the decals are not ideal. Then I will paint the exhausts. After some weathering and a flat varnish, the fuselage dome light and mirror will be painted. Thankfully this Spitfire did not have an antenna wire fitted so that's one less thing to worry about.
That is looking gorgeous Joe. I had a problem with the gun patch decals on my build and ended up gluing them on with PVA. I wanted to use them because they sit slightly proud of the wing skin, a bit like the actual material that they used in the day. Looking forward to your finished photos.
No sign of the paint troubles now joe , looking mighty fine
Looking great with the decals on Joe, the end in sight :coffee:
Cheers Steven, nearly there :cool:
Thanks Steve. I think in 1/48 or smaller, painting the patches is going to be sufficient. Certainly in 1/32 slightly raised patches would be the way to go.
Cheers Tony.
The decals were superb, very little excess film on any of them; even the squadron codes were designed so there was no backing film showing. Will check on it soon, and press on.
Looking nice Joe. Probably my favourite camo' scheme for a Spitfire.
Just caught up with your build Joe. She's looking great! I used painted squares of Tamiya tape for the gun patches on my build.
Nick
Looking really good.
Cheers Jim
Looking very tasty mate.
Cheers Paul. Nearly there...
Nick
Cheers Nick. I did contemplate using tape but just went for paint in the end.
The gun patches came out well Joe. Nearly at the finish line now.
Cheers Steve. Yes, nearly finished.
All looking very lovely Joe 🤩
Geoff.
Cheers Geoff, looking forward to it leaving the bench
