GRASS AND TAMIYA PAINTS
Seems from reading about using Mr Hobby as the primer, it will have a sheen, as you will have noticed. There is a Tamiya colour I could spray over this, which is a slightly different brown.
Now need to find the smallest pipette on the market as will only need small amounts of paint, so any ideas please. Been going through pipettes at an alarming rate, is there another method of getting paint out of the bottle using this way?
Just been looking at Amazon, have sent for some glass eye droppers , total content 1 mm, so these should work
John.
Drinking straws work John. You can cut them in half so get twice as many. Put the straw into the paint and then put you finger over the top to seal the tube. You can then transfer the paint. Keep the straw vertical. OK it is not perfect, you need to have the paint jar as close as possible to the airbrush but it's cheap and it works.
I have a good selection of grasses, ground cover plants, little shrubs, etc now, and I tend to mix and match them, so theres some dark, some light, some medium, etc, seems to look ok. Other than that I just add a few dabs of paint or pigments or a wash, etc as a final touch if they need it.
That's an idea Jim:)
I used to do that Peter, but just wanted to try out using paints to change the overall look .
I reuse my pipettes many many times, my current pair have been on the go for at least a year. Eventually they split and need replacing but I certainly don't use a fresh one each time 😲
I have one that stays perfectly clean, only ever used for dispensing clean thinner, then another for everything else. After use I clean it in a small jam jar filled with lacquer /standard thinner , sucking and squeezing several times to flush it out.
Hi Andy, yes I've one for MR hobby levelling thinners, another for gun cleaner, the glass ones I've recently bought can be cleaned out. I found I was using so many plastic pipettes with different colours, pluss being able to see the amount in the tube, hence the glass ones.
