Geoffs Trumpeter 1/48 MiG-3
Geoffers
Shropshire
Geoff
Shropshire
Firstly thank you to Neil for hosting this group build.
This will be my entry, I collected it from the Post Office this afternoon.
This will be my first ever Trumpeter kit build so I’m interested to see how it goes together.
It looks nicely detailed and I have bought an Eduard PE set mainly for the seat belts and a mask set which makes masking so much easier.
Here’s the plastic parts.
Clear parts look quite nice.
Instructions.
Paint guide
Transfers.
Extras.
That’s it then, I might start it next week depending on progress with my other builds.
Thanks for looking 👍
Geoff.
Good to see a Prop version of a Mig too, looking forward to this,
Nice choice Geoff.
Thanks Joe 👍
Excellent choice, sir. Which paint scheme were you thinking of?
Cheers Chris, I’m going for the third scheme “white 5”. I quite like the yellow spinner 🙂. Trumpeter don’t give any information regarding the schemes but I’ve done a bit of digging and I think was apparently a flown by Soviet ace Alexander Pokryshkin.
Thanks Neil 👍
Great choice Geoff
Cheers Steve 🙂
Geoff.
A little late to the party but the build is finally underway 🥳
I’ve basically just removed all the parts needed from the runners and given them a clean up.
The small parts had a tiny bit of flash but otherwise it was just a case of trimming the attachment nubs.
Cockpit is fairly detailed and I’ve got some PE to jazz it up a bit.
I’ve glued the wings together now and mounted all the cockpit parts to lolly sticks ready for paint.
Once the cockpit is sorted it should go together quickly as there really doesn’t seem much too it 🤞
Hopefully another update soon.
Geoff.
All the best people are fashionably late to the party, Geoff, so welcome! Beverages are available in the kitchen, cold or hot, your choice. Enjoy.
Cheers Neil, sorted 🍺 😅
Nice start Geoff. I think that White 5 scheme is going to look great.
Thanks Joe, yes I thought it looked a bit better than the others 👍
Geoff.
Hello,
Despite my lack of updates I have been labouring away with it 😅
Firstly was getting the cockpit sorted and painted up.
Some PE to add too which slowed it down a bit.
Paint colours where a bit of a puzzle as different colours were used at ditstages and also depending what material was used as it’s a mixed wood/metal construction.
In the end I settled on what you can see in the picture.
I used UV glue for the first time to replicate the instrument panel glass. I didn’t realise that there was a bit of an overspill but apart from that I’m happy with the effect it gives.
Here are the parts after weathering.
This was then joined together before being sandwiched between the two fuselage halves.
Apologies the pictures aren’t the best 😕
The rest of it has been built up, wings and horizontal stabilisers added and the nose area built up.
It all went together with no particular problems and here’s how it’s looking.
Just the flaps to add and a bit of a clean up then it will be ready for priming 🙂
Hopefully another update soon, thanks for looking 👍
Geoff.
With all those inlets, it's a good job they made the engine cover a separate piece, rather than putting the seam down the middle
Don't even think about the potential nightmare of filling and sanding that! Brrr!
Looking very nice indeed Geoff
Thanks Ian 👍
You’re right Chris it would have been, let’s just say challenging 😵‍💫
Geoff.
I was thinking the same as Chris, they obviously gave thought to seams and detail. Looking good Geoff, the cockpit is very nice indeed.
Just dug out my part-built 'Flashback' MiG-3, which has pretty much the same parts layout, and happily the upper engine deck. It's twenty-years old, plus, and is apparently an ex-Eduard kit, which includes a load of resin and brass extras
I got it as the 'plane of my Political Officer character in my partner's Soviet Aviation WW2 table top RPG. Za Rodina!
Nice work geoff , its coming together oretty quick now . Looks like the same parts breakdown as the 1/32 trumpeter mig 3 ( without the needless PE hinges )
That's come together nicely. Trumpeter often have a lot of very fiddly parts but this looks more sensible. I like the scheme you've chosen. Steve's observation regarding the engine cover is spot on. A join down the middle would not have been fun.
Interesting to see this is going together well as I've never built one of their kits either, but have a couple of kits in the stash.
It's looking excellent btw, great work on the cockpit. I've never actually built a Soviet WWII fighter but I can see me getting this one at some point. The Mig-3 is such a cool little fighter.
Sorry for the late replies chaps 😳
Thanks Joe, I’m pleased how it turned out 😊
Sounds interesting Chris 🤔
Nice work geoff , it’s coming together oretty quick now . Looks like the same parts breakdown as the 1/32 trumpeter mig 3 ( without the needless PE hinges )
Thanks Tony, I’m very glad it hasn’t got PE hinges to deal with 😮
Cheers Jim, yes it’s a nice little kit 👍
Thanks Darian I’m enjoying the build, I’d certainly recommend it 🙂
Geoff.
