Off to a heart specialist!
Made an appointment privately with a local private hospital . Seeing a consultant on the 1 oct . Was concerned about how long a wait I would have with the NHS.
Having a date is such a relief.
Hi John. When I went to A and E with my embolisms a couple of years ago I was seen and on an ecg machine within a few minutes, and assessed quite soon afterwards. After that I had an appointment with a specialist, was scanned, X rayed and ultrasound tested, and on treatment within 24 hours. That response reflected the seriousness of the issue, which was potentially fatal (even though I thought it was basically a sore leg and was just a bit breathless). The speed of response was absolutely tied to the seriousness of the situation. If yours isn’t moving this fast then I wouldn’t worry too much. You may well get an NHS appointment before Oct 1st (my birthday 😺) so keep your options open.
That was impressive treatment Tim, good job they reacted like that.
Going to be a good day then, your birthday and my appointment 👍
Hi Wobble,
The date with the specialist is kinda way yonder. Over here we get to see the specialist within the day regardless the situation also depending on whether you are free for the day. In between the waiting you will be sent for blood tests and whatever is required for the appointment with the specialist. Usually a letter from your GP will speed up things. Perhaps we don't have many with major medical problems to crowd appointments.
So if they have put you for 1st October then I think they must know what they're doing. When you made your appointment did you furnish the specialist with your GP's examination or referral?
Good luck Wobble and hope all turns out well.
Wabble
Hi Wobble,
Wabble
Wabble I did indeed. Here in the UK a referal with the NHS to a specialist can take some time. Not wanting to risk waiting several months, I decided to go privately. I f howevr I had ended up like Tim in A&E things would have gone quicker.
Wobble
