Brave New World - Epoxy Resin U Boat Dio
pjgtech
Peter in Kent UK
Swale Kent UK
Peter
My first foray into the wonderful World of Epoxy Resin!!!
Built my little sub a while back, and it came out quite nice for a reall el cheapo kit, so it sat on the shelf for a while, and I kpet looking at it, and an idea started to form.
Could I do a little dio with the sub? But maybe have it actually submerged?
I've done water, via loo paper and pva, but that would not work for this.
I've done water via the gel type materials, but that would not be suitable either, I'd need a lot and its not cheap.
Started wtaching YT vids on epoxy resin..... so we know where this is going, right?
My plan is to have the little sub in a sort of rectangle shape, with it submeged, maybe with its periscope just above the waterline.
I want to set it in epoxy resin, but you need to do it in layers, so its needs to be planned well.
I want the bottom to be the seabed, with rocks, etc and a darker colour than the sea.
Some materials were bought....
Could not quite find the exact size shape container I wanted (using silicone mould) but this small bread loaf tin shaped one might work?
Got some resin and harderner (1:1 mix).
Got some colours to add.....
Few pieces were placed.... and the first layer mixed and colour added....
Dry fit to make sure the sub fits, it will not be on the bottom, it will (hopefully) be suspended mid water or near the top...
Then there was no more prevaricating, it was time for the first pour, lots of stirring/mixing..... colour added...... then it was carefully poured in and left to set.
This is my first attempt, so i fully expect to cock it up at some point, and also deliberately used a cheap model, and cheap materials, etc, as it will be a learning process for me, to see how this epoxy mallarkey all works. I'm gonna leave it overnight and then it will get another layer (slightly thicker) of nearly clear, slightly blue resin, then the sub will be inserted on the next layer, then hopefully the final layer will complete the build. I might try and introduce some waves into the final layer too!
Getting rid of bubbles is interesting, various methods noted, eg: gentle stirring to prevent bubble sin first place, apply gentle heat (via hot water bath or warming pad) to evaporate bubbles, gentle pricking of any large bubbles with a needle, etc, lastly apply direct heat via hair dryer, or other heat source, heat gun, small gas battle, etc!
Allowing time for each layer to set (between layers) also seems to be varied, depending on the mix used, 1:1, 1:2, etc, the temp of the area, the thickness of the layer, etc. My first layer was quite thin, so I'm leaving it overnight, but some peeps seem to only leave if 4-6 hours, some seem to leave it 24-48 hours, so we'll have to see how I get on. Its an interesting process though, and I can see how peeps can go down this rabbithole too, Lol!
Jsut did the second layer, had lots of tiny bubbles this time, left it for 30 mins, but they were still there, so got the heat gun out and gave them a blast for 5 mins, seems to have got most out, we'll see what it sets like, last layer took a good 10-12 hours to fully set.
This second layer is a bit thicker so I reckon 18 to 24 hours this time.
Next layer will be adding the sub in place, will need to suspend it in position, prolly using BBQ sticks across the top or similar and invisible thread tied to the sub.....
Put a cup of resin in one of these for 10 mins, it will remove all the bubbles and come out crystal clear.
Great project peter its going to look brilliant , although youre in trouble when the mrs cant find her loaf tin
Second layer of Epoxy Resin in and have now attached the sub, invisible thread glued to each end, then wound round some lollisticks at the correct height, so the sub is at a slight angle, both sideways and the front lifted up slightly so it should look like its surfacing, the periscope, etc should just be coming out of the top. Next pour will cover most of the sub, then will prolly need at least one more, maybe two, depending on how deep it needs to be.
Happy with the colour, I'm trying to go lighter with each layer, darker at the bottom....
Had to put tins on the lollipop sticks as the invisible thread (elastic) was trying to unwind itself, so needed to be slightly weighed down!
Uboat in Resin sept26 2 (1) (Large).webpUboat in Resin sept26 2 (2) (Large).webpUboat in Resin sept26 2 (3) (Large).webp
Got some sort of weird "crackle" effect going on, not sure why, prolly did summit wrong, but I quite like it TBH, so it is what it is.
Sorta makes the water look like its flowing/moving?
Schoolboy error, Doh!
Last night I did a late layer pour, but had a few bubbles, So I got out the heat gun and gave it a quick blast, but, I had now added the sub to the resin/container..... and the sub is made of soft melty plastic...... so......not realising I had placed the heat gun a bit too close, and for a bit too long.....the periscope melted slightly and bent over! (and alos the large antenae thing)
I did not actually notice last night.
Came down this morning for the next layer pour and noticed a droopy periscope, etc....Bah!
I thought oh well,, nowt to lose now, so got the heat gun out again, gently heated them up a bit and managed to get them sort of upright again, but a bit of the detail from the periscope and antenae has now gone, and it still looks a bit wobbly.
TBH as its so small there was not that much detail on it anyway.
This was always meant to be a learning exercise for me. So what have we learnt.....?
Don't let silly Oafs near the heat gun unsupervised!
Onwards and upwards, we carry on..... ;)(y)
Think this will need one more layer, tomorrow morning, just did another layer buts its not quite there yet.
So should be finished tomorrow and then we'll see what we've got.... 8-)
Last nights layer pour.... you can see the wobbly bent / melted periscope! [Bah!]
Then here is this mornings layer pour, almost completely covered now, just the tip of the periscope poking out....
NB: I know the sides are a bit "wavy".... this is a silicone bread tin mould, so its very soft. So obviously ones of the lessons learnt from this experiment is to use a more rigid container, sides, etc. However, I think the "waveyness" adds to the seascape look?
I'm now debating whether to have one more thick layer to completely cover the periscope of not?
And, whether to try to add some sort of wave texture as the final layer dries?
This will involve checking the resin to see how much its set, probably about once every half hour, maybe once an hour, until it gets to the point where I can manipulate it to introduce a final wave texture, probably uisng a pallet knife or similar.
Quite happy with the colour, I've tried to go lighter blue with each layer, darker at the bottom, etc, as if its too dark you would not be able yo see the sub! I won't know until the final removal from the mould, whether there are lines between each layer pour, hopefully not, but it can happen apparently. What I'm hoping for is a sort of smooth transition from one layer to the next....
