Worst /best kit you’ve built.
Geoffers
Shropshire
Geoff
Shropshire
After a few shaky moments with my last build I was thinking about the worst and best kits I’ve built.
Not how they turned out in the end but what the quality/engineering etc was like.
Worst was quite a recent build,
a Italeri 1/72 Dakota. Generally poor fit, some structural parts didn’t even touch which made it a challenge but the worst part was a fault with the clear parts. Unfortunately I think it was an air bubble or something inside the plastic as polishing made it worse.
In the end it sapped my mojo so much I took the nuclear option and flew it into the recycling bin 😡
Best was a Eduard 1/48 Spitfire Mk.I which was sublime. Very detailed but great engineering made it a very enjoyable build.
The transfers get a lot of bad press but if you are careful they are very good.
That’s mine, what about yours?
Geoff.
I will need to look in my cabinet Geoff, but the Academy A-10 was a bit of a filler eater and a real challenge to create something decent for public viewing. I'm sure I've got some other monsters awaiting me in the stash. I built the Italeri Dakota too, got it completed but as you say it was a struggle.
Best kit... I have many happy memories of some builds. The best in recent memory was the 1/72 Tamiya FW190D I built for the Alan G memorial GB. Hopefully I have many more enjoyable build experiences to come!
I had the worst feeling with an Italeri (2786) "1/48th Lockheed Martin F-16 A Fighting Falcon", bad fit, wrong details. Old kit in a fancy new box. Made me avoid buying Italeri ever again.
I had better fun with the Eduard 1/48 Spitfire Mk.IIa (84206) and Eduard 1/48 A6M3 Zero type 32' (84191)
Worst would be the dh comet recently but that was simply cos it was a 65+ year old kit in the modern world......... I hate Eduard, never had any luck with them.... My jinx brand
Best kit is hard to pin down..... Years ago I did a hasegawa Datsun 240z that went together perfectly that comes to mind
For me the worse was the Kitty Hawk OV-10 Bronco in 1/32 scale. Truly a terrible kit in every way a kit can be bad. Fit, engineering, moulding, instructions, decals, it had no redeeming features at all.
The best, well it has to be the Kotare Bf109k which just pips their Spitfires to the title. It was a dream build of perfectly fitting and engineered parts, superb instructions with some great schemes in the box.
Hmm, tough one, as I'm relatively new, not done that many kits, and I don't remember any bad kits from my Yoof?
The recent old Comet kit wasa terrible fit, so maybe that one.
Best one, hmm, possibly my recent SAS Landy? or my last 1:35 scale Tiger tank turned out quite well.... dunno really...
The best, I remember with great fondness, was the Tamiya 1/48 A10C - but that was from doing it 40+ years ago - the last one I made before I went to Uni and took a 'break' for the next 30+ years. Most recently, the Eduard 1/72 F6F - that got me back into the building bug.
Worst, without doubt, Revell Bell Huey - terrible flash, terrible fit, recycled. I do wonder, in hindsight, if I should have given it longer and tried to wrestle it into shape.
Worst is easy. Anything by Amodel, but specifically their 1/144th Canberra. Detail and scale are fine, but the engineering is simply appalling. Everything is just butt joints, and when you've got six separate parts to the fuselage, aligning them is a nightmare
Best kit, probably the current Airfix Mk.I Hurricane, which practically falls together, and I think I've now built, in different forms, three times. Second would be the Tamiya 1/20 Honda RA272 F1, even though that kit is more than thirty-years old. Quality engineering
Best was an Eduard FW190 for the group build, closely followed by an Eduard Zero, also for a group build. Fit, finish, instructions, decals, etc were all top notch on both. The Airfix Spitfire I did a couple of years ago was excellent as well.
Worst, in recent memory anyway, was the Trumpeter 1/48 Avenger. Everything on it seemed to be a bit of a struggle, the wing fold parts just didn’t fit without an age of sanding, for example. Nothing seemed to fit first time, and I was glad to get to the end of it. I think the 1/48 had been ported down from the larger scale 1/32 without any appreciation of the change in tolerances reduction in size would make.
Another poor kit was the Tamiya 1/48 Mosquito. I found the kit hard work. The mould lines were pretty poor, detail was quite soft, and the fit of the nascelles was not at all good. I was particularly disappointed in this one because it has always had such good reviews. Could just be the moulds are tired and the kit needs a revamp? I couldn’t recommend it to anyone though.
Thanks for all the answers, interesting to see the variety of different manufacturers that have produced diff kits.
I was expecting certain brands to be more heavily represented 🤔
Geoff.
The worst? It's a toss up between the AZ models Mohawk or the Special Hobby Spitfire PR mk.X. I guess it must be the Mohawk because that got binned whilst I did actually finish the Spitfire. Both were truly awful!
Best kit... That's a hard one. Always the last one I built? 😎
Interesting that you found the Tamiya 1/48 Mossie so bad. My only ever ‘commission build’ was for a friend using this kit to replicate the aircraft his father flew in the far east. A silver painted Mossie (pictured) and while not the greatest kit I found it rather good.
Mind you, not a patch on the amazing 1/32 Tamiya Mossie which must be among the best plastic kits ever produced. If you have not built one I really recommend you do.
Worst is Airfix 1-72 DHComet by miles.
That said, it wasn't originally made by Airfix but by a German firm in 1957 if I remember correctly ( according to Scalemates).
Best was Tamiya 1-48 Beaufighter, practically flew together.
Interesting Barry. I built mine as part of a group build on here, and at least one other member had similar issues. Details here….it was mostly poor fit of the body and tail. I was experiencing bad RA flares at the time though, which I’d forgotten , so that could’ve coloured my experience . https://www.scalemodelling.co.uk/threads/tims-1-48-tamiya-mosquito-fb-mk-vi.30471/page-7
I'm going to throw out something controversial here... One of the best kits I've built in the spirit of 'fun and enjoyment of building' was the 2009 tooling of Airfix's Mig-15. I know, I know, the fuselage was the wrong scale and shape, and the panel lines were awful - but from a standpoint of pure fun, I'll build one any day. It's just a shame they're hard to get now.
