I normally do put decal fix on the underneath and on top then seal with what ever varnish you need.HI all ive just fitted the decals on the chopper now do i just brush this decal fix over the decals to seal them down or what ?
chrisb
Got me there Chris, microscale stuff comes in red and blue bottles, but they are both clear solutions….got a picture?ITS A CLEAR decal fix Tim
chrisb
WELL Tim since this model has been suchIf that’s happening Chris, give them a coat of the liquid decal film you already have. That’s exactly what it’s supposed to help with….
As to cost, to be honest, not sure, once you have it it lasts forever. I’ve had mine for at least ten years….
……Just looked it up in John’s shop and it’s 4.75……
HI Richard yea i will do what you say on the other 3 seaking decals an cheers for your info as wellChris, you can't use Decal Film when the decal is already on the model. Coat the decals while still on the decal sheet, when dry cut as close to the images as the Decal Film creates a layer of film over the decal. Put your cut pieces in lukewarm water, remove and place on tissue, as soon as the decal moves easily on the backing paper it is ready to slide onto your model.
The Red Decal Solution is applied after the decal is placed in the model...let it do its wonders until the decal conforms to the surface. Don't touch it as they will look wrinkly at first but will settle flat.
