HI Guys an Gals while im waiting for the wheather to warm up so I can start my HMS TIGER build as its got to be built in the garge due to size. An I don't feel im ready to build my big plane kits YET
I was thinkin about a bit of humour of an on site thread.An as the title says i'll begin. It was in the late 1960's havin been building small plastic kits for a number of yrs an makin some right bodgers up of them that my older brother said why don't you build a fliyin plane kit.
So he bought me a kiel craft kit of a F 86 SABER in about 1/32 scale with a jetx 50b engine an fuses an fuel pellets so I spent wks building this kit made up of 2mm x 2mm balsa stringers an balsa formers an then covering it with tishue paper an then dopin its to give it strength an then fitted the jetx engine to the plane an I was so excited that I dint bother to paint the plane
I just wanted to see the plane in the air flyin so I took said plane out into an open field an as I was smokin then I took out my ciggrette lighter to light the fuse on the jetx an all I see was a bright flash of light an I was left holdin the engine an I looked down an saw a outline in ash of the plane an I could not believe it . In my haste to fly it I had forgotten that I should have stuck on the plane
tin foil to take the heat from the engine as the glow red hot when running an i also should have bent the fuse outward away from the plane as again I forgot that dope was hilghly inflameable so that was a shock to me not to be repeated END Now come on guys an lets hear your stories of a mistake you wont make again in a hurry as im sure you must have some what with all the espertise on here
chris
chris
