hello everyone, don't know if I have done this right as im still learning how to use computers !, anyway heres a few pics of revell 1/16 scale rolls continental im building for some one
thanks will post more pics as it progressesHi Raymond
Welcome to the forum. I am sure you will enjoy your time here.
Looks like you have made a fine start on the RR. I've not seen this built before so interested to see how it goes.
hi , how did you find the fitment of parts, only mine need a lot of filling sanding etcHi Raymond built this a while ago when my mojo was low good kit sure you will do a better jib than me, off to a great start
like this you meanI must admit the fit was ok but the same kit can vary depending on where it was stored kits can warp (stored in the warehouse next to the heater for instance)
Hi Raymond. Looks like you forgot the photos in your last post. Also you do not start a new thread for each part of the build, just carry on in this one.
ah right, getting the hang of it slowly !Wow that is bad.
actually making this for someone else, once I show him the steering he may want it glued in place !A welcome from a me as well Raymond .
Going to enjoy this. At least you can say you have a Rolls !
John.
lots of moving parts on there, these bits are always fragileHi Raymond
The flimsy steering is a common problem with these car builds. I built an SS100 Jaguar and once I had decided how much of a turn I wanted on the steering I glued it all solid.
You can see how many pivot points there were and how loose fitting it all was.
