- Joined
- Apr 27, 2018
- Messages
- 15,027
Hi all I need help, we know that I can hear you cry. I am having real issues with using my airbrushes. I never seem to be able to get the balance right of paint thickness and air pressure. I use an Iawata and a steenbach and have the same issues with both so I know its not them at fault.
The first as you can see from the picture is spidering I was trying to spray really thin lines one second it sprays a perfect 1-2mm line then its starts to spider or splutter or stop completely.
The other issue is the airbrushes stop spraying but when you release the trigger it sprays a bit operate the trigger and it stops release the trigger and its sprays a small amount.
This is the spidering
I usually use Valejo paints but have also tried Tamyia and get the same results.
Any help or pointers will be greatfully received, I am pulling my hair out.
cheers
Scottie
cheers
Scottie
