Hello Mark,
Lots of good advice given above.
I use a variable temperature electric iron and low temp solder. things to remember is jig up the parts if you can, I solder on a thick smooth kitchen floor tile, that allows me to draw angles if I need to and I have also secured two 6 inch metal rules held down with double sided carpet tape as a permanent 90 degree.
I also use a torch and Carrs solder paste which you can brush on or apply with a tooth pick depending on the area to be covered.
The other item is have a look on you tube at a guy called Plasmo, he does a tutorial just for beginners, and there is not the usual 24 hours of waffle before hand, you should be able to pick up a lot from him.
Do not be worried, get some old brass etch and use the video above and get some practice in before commiting to the real job.
All of the etch brass bar armour on this Leopard was soldered with a torch and solder paste using the toothpic method, and was the first time I had used a torch.
Hope this helps,
Mike.
