Airfix 1/72 Spitfire Mk1a
Hi I'm going to build this as a comeback build, it was a present with my breakfast this morning from my good lady.
As you can see I've already started I've cleaned all the parts up ready for assembly.
Painted the cockpit add a decal instrument panel.
Assembled the two halves of the fuselage and had to re cut panel lines.
Assembled upper and lower halves the main wing.
I must apologise to the real aircraft builders on forum I'm just seeing if I can still glue two bits of plastic together before I go back to building my tanks so please bear with me.
Pete.
I was under orders from the good lady to start this she said it was good therapy and I'm not going to argue ;) .
Pete.
Hi had a good day building this little beauty.
Cockpit is only a dry fit.
Thank you for looking in.
Pete.
I had that as a Father’s Day present a few years ago. It’s a cracking little kit I thought.....looks like your enjoying it as well....
Hi Tim it's a great little kit as you say and great fun to.
Pete.
Looking good Pete. Good to see your getting back to things quickly....... Even if it is under duress from SWMBO!!!!
ATB
You didn't hang around there Pete! Glad you've returned from hospital with the modelling juices topped up. Great work so far.
I love building Spitfires. Its one aircraft that every time I pick it up you cant help but marvel at its design. Enjoy your build Pete. Looking good so far.
ATB
Looking good Pete, nice to see you back :thumb2:
Steven
Pete,
As the others have said its good to see you back building.
Nice start back Pete .
Thank you all very much for your kind comments and looking in very much appreciated.
Cheers Pete :thumb2: .
Well I thought I better post something otherwise people will think I'm just laying around in bed drinking cups of tea.
Got the hairy sticks out and got the primer coat on.
Added the camouflage, decals and clear coat.
Next up I'll be adding some weathering, dulcote and painting the canopy.
Pete.
Great work. I'm not sure they built them that quickly during the war.
Lovely looking spit pete , ive got one of these in the stash , i must get it out sometime, cheers tony
