The major components did not fit quite as well as the rest.
In fitting the wings I had a choice, a wide gap at the top of the wing and the back flush or a narrow gap at the top and some filling of a sunk area at the back. I chose the latter and used Vallejo Plastic Putty to fill the sunken area with a smear to sort the top wing/fuselage join and Mr Dissolved Putty on the seams. I will use my David electric sander tonight.
Above you cn see the filled area.
Below, the cockpit.
You can see a little sanding on seams is needed, particulary on the small area in front of the pit.
Below, the cockpit.
