1/35 Great Wall Hobby 12. 8 cm Pak 44 .
Hi John
That is really stunning stuff. You are the building master builder :thumb2:
Really fine buildings. Your love of the subject shines through John.
Good evening from Race Towers.
Been a good day finishing the major assembly, still a lot to do , those little things that catch the eye. With out more ado.
Started by gluing the supports at the back.
The lower sections have been painted black as the doors will be open .
Little more to do on the pipe and of course the edge of the brickwork to the base.
Drinking straws have been used for smaller pipes and those flexible parts are perfect for corner joints. Will be weathered tomorrow.
Two sets used on the right hand .
Pleased with the sign .
Doors on, black backing had already been fitted, bottom of doors need a little touching up.
The flange will need a little attention, I cleaned up the paint work using 800 grit wet and dry on the pipe.
Comments welcome, thanks for staying with this.
John.
This is great stuff John. Colouration is spot on and attention to detail is first rate.
Great plumbing, still can't get over how well your paving stones came out. PaulE
That really is turning out to be an exceptional set of building fronts. And I genuinely mean that.
The one looking straight into the little recess at the small door in particular, looks very realistic and almost lifelike.
My only criticism, and it is a small one, is that there seems to be lack of any combustion, fires or major conflagrations...... ;)
This really is going to look amazing once finished.
ATB.
Thanks Tim for your kind comment.
Evening John,
Getting better and better mate.....Nice touch with the no smoking sign :thumb2:
Thanks Si, just printed out some Gothic style on Word and stuck it on that piece of stirrer. Left it smaller than the wood to look more like a sign .
Tremendous bit of work John, very realistic.
Andy.
Thanks Andy .
Outbloodystanding
Paul cheers .
Superb John. Looks like you're having fun.
Cheers John, I am indeed .:thumb2:
Loving it. You're excelling yourself here.
Thank you Peter, kind of you to say .
SUPER... love it..i can't wait to see the final reveal...
Not long Greg, about another week or two ! Glad you like it .
Thanks Paul, your not the only one, Christine even mentioned them looking real !
Great seeing this come together, 453.
Thoroughly and totally a pleasure to watch.
570
570 Glad you approve and are enjoying it.Thank you .
ATB.
Andrew at the beging I had thought of burning the timber joists, as I have done before, but these buildings had metal sectional roof supports, so unfortunately no fire , just damage .
Thank you for the comments about it liking real .
Cheers Neil.
I'd have liked more roof, but in keeping it within the base size ment cutting it back .
Can't have it all ways. Thanks for the great comments, only fellow modellers can really appreciate the work that is put into our hobby.
John .
Hi John, just had another look through and still think it’s great. One thing that stands out to me though is should there be some sort of flashing where the pipes enter the building? They wouldn’t be weathertight otherwise....
Yes Tim I did see that, need to address it , should have really made the holes before the scribing, then could have done circular brickwork .Of course I never think that far ahead, :crying: will have to add some filler, cement coloured.
Several other small details to be done, including jointing collars on the drain pipes into the ground, and some cabling fixed to the walls. Anything else please shout out, even thought about a light, but considering it's wartime maybe they didn't have any .
