Trumpeter 1/24 Hawker Hurricane IID trop
BarryW
I rather fancy building a Hurricane, one of my favourite aircraft, but disgracefully, there just is no decent new tool Hurricane in 1/32 scale, just an ancient Revell and some problematical short run kits. So what other options are there, no I’m not interested in a teeny little 1/48 so it’s over to 1/24.
There is the Airfix, a decent kit for its ancient vintage, it was the third release in the Airfix 1/24 series and was a real improvement on the Spitfire and 109 that preceded it. I remember it well having built it back ‘in the day’. But there is something newer from Trumpeter and I have not yet built one of their 1/24 kits so it has to be one of these. Reviews are good and it really looks like a Hurricane.
Some Googling found a Mk IIC and a Mk IID available, I have seen plenty of the former around on the web but few of the ‘D’. So a D it has to be.
The D was an attempt to benefit from the Hurricane’s stable gun platform and ruggedness to produce a tank killer. They put a pair of machine guns in the wings armed with tracers for aiming and strapped directly under it, below the wings, big powerful cannons. This, along with a Volkes filter for use in the desert, affected the aircraft’s performance but that hardly mattered as it’s mission was to kill tanks not engage in air to air combat.
So, it’s a Hurricane, not as we have seen it before but what’s not to like, Hurricane, desert camo, unusual configeration..... this is going to be fun.
Here is the box
Here is the aftermarket
It is a little disappointing to see how little 1/24 am there is. No choice of seatbelts other than those shown, not my favourites exactly. The canopy masks are vinyl, no Kabuki tape ones available so thats no great but will have to do. The i.p Is great though.
This is the scheme I will do doing.
I find it amusing how much care Trumpeter take over the packaging of their utterly useless decals. These will be binned, apart from the aircraft serial codes which I will use with a coat of liquid decal film, it is not worth even putting these in the spares box, so useless are they.
so, I will be using these instead.
This is a generic Hurricane set from which I will be able to make up the right markings. These, unlike the Montex masks, are Kabuki tape so will be much better to use. Maketar do produce a lot of generic masking sets offering a choice between vinyl and kabuki. Never pick vinyl, they just cannot be chamfered down into detail in the same way kabuki ones can and on curves can come away from the model. As I have this set I just might need to build another 1/24 Hurricane or two.....
If you want to paint on markings then you cannot go wrong stocking up on the generic Maketar sets.
The plastic looks good, nicely detailed but I found it a little oily, something I notice with Trumpeter. So I actually did what I usually do not do, washed the sprues in a sink of warm soapy water. I will still need to wipe the parts over before painting with some ipa to get rid of finger grease.
I was surprise as the kit does not seem to have many parts but the detail seems fine.
As usual, here is a shot of my bench, all cleaned up, set up for this build. The sprues are labelled and organised.....
I also made a bit of a start on the cockpit...
More to follow....
I saw a good tip for using vinyl masks - stick them onto Tamiya masking sheet and use them as templates to cut the masks from the Tamiya sheet.
Good thinking - I just might do that for the canopy where there is a curve....
Hi,
Will follow, would like to build a decent Hurricane, but as you say not much to choose from.
Good luck
Alun
Corn popped, coke poured....
Wonder it Tamiya will spring a Hurricane on us Monday?
Nah, they’ll wait for Barry to finish this one first......
Hi Barry, I'll be watching this as I have the same kit on the shelf. I had wanted the IIC with the hispano cannons but could only get this at the time.
Would like to see how it looks built up as I fear the hump curvature appears slightly exagerated making the rear stunted looking. Perhaps its been corrected in the later molds I hope. Trumpeter has at times gotten their shapes wrong with some kits. Fingers crossed.
Hi Barry
Looks a nice enough kit for you to work your magic on. Painted on markings are always nicer looking. What makes the kit decals so useless?
Hi Barry
Trumpeter decals are prone to disintegration, splintering into tiny pieces. They are also resistant to confirming even with the strongest solutions. Even worse than Tamiya decals. Besides painted on markings are far superior specially in large scale.
I agree with Barry on the painted of markings in larger scales. Looks more convincing and not having to sand down the decal film.
I had a fair bit of time today and the house to myself for the morning so l plugged on with this.
I did a dry fit of the cockpit assembly.
Perfect
I pulled together some other cockpit areas including the door and fuselage sides.
And primed the cockpit parts
I have also put the engine together. This will really be just for attaching the prop and exhausts, it won’t be seen so I am not painting it. I also left off a few parts.
I have to say that I think Trumpeter hit a sweet spot with the engine. It is nowhere near as superbly detailed as the Tamiya 1/32 Merlins but It builds up really well and offers a great base for super detailing if you’re are so inclined. While it also offers enough to satisfy a casual modeller and those who, like me, want the model completed all closed up.
All in all I am impressed with my first Trumpy 1/24 kit so far. I would describe it as a battery recharger... or mojo rejuvenator build. Just what is needed after a long detailed complex kit.
It’s always great to find a photo of the actual aircraft that you are modelling. I have been doing some research because the instructions suggest the yellow I.d. strips need painting on the leading edges of the out wings and also that the code letters are white, neither seemed right to me. I first found, on Wings Pallette, several pictures of this aircraft all with MSG codes with no sign of the yellow. A bit more Googling and I found...
it clearly shows no yellow leading edge.
it is always worth checking up on instructions to see if they are right. I have found Trumpeter and Airfix, among others, to get this kind of thing wrong quite frequently.
I will carry on with my research and will post any more pics that I find, if any.
More pictures, not necessarily of the specific aircraft I am building but all add to the trail of evidence of how I need to depict this aircraft.
Here is a colour print that suggests the codes should be Sky - so, MSG or Sky, I think MSG but I am not certain. Anyone else have a view?
These are IID’s of 6 squadron but not necessarily this aircraft.
There is this on the 6 Squadron website, what a great picture though not necessarily evidence of anything.
