Revell/ICM 1/35 WWI French Infantry 1914
Glad to read I'm not the only one that has paint come off If I paint the same way Neil. Will try the Peter way next.
Steve, Andrew -thanks a lot guys.
John- good luck and keep us posted.
Well here he is, the story so far.
It does feel strange to totally finish part of it and not to have even started other bits, but at least there's less risk of damaging the higher parts. Just his legs and feet to go, plus a bit of work on his kit. That blue badly needs matt lacquer, but it will have to wait till it's all done. And that makes the gloss varnish on the belts redundant, but hey ho, you live and learn :rolling: It's too glossy anyway;)
I struggled getting a clean division between the sleeves and the hands, I might start leaving the hands off and painting them separately.
Anyway, that's all for now, thanks for looking
Neil
Nice progress Neil. Still playing air guitar as well.....
Just had a read through of this neil , i completely missed it last year ! Excellent work , he looks great . Those instructions are terrible , good job youve got the book , cheers tony
Hi Neil
Looking good. Interesting approach but certainly works. Tim's "air guitar" post made me smile :tongue-out3:
I'm calling Frenchie Numero Un done.
Not too painful - I think I'm starting to get the hang of this painting lark.
I just need to do it more often so I don't have to re-invent the wheel every time!
It will probably be a while until I do his amis as I've still got five of his ancestors to finish, but he was a welcome diversion. And if I need another diversion I think it will have to be KHAKI!
Thanks as always for looking and liking and commenting.
Neil
It definitely works doing it that way Neil. He looks good.
Found the other way disappointing when you suddenly notice the boots were needing redoing still you were working on the uniform at the top .
Must remember when I do mine .
Great job with the figure it's something that terrifies me, I have only done one (not very well) but he is virtually hidden in the digger cab.
Andy.
Neil,
You certainly are getting the hang of the painting lark, that's a cracking result.
Cheers Paul:thumb2:
Thanks John, it really does help actually. And leaving part of it completely unfinished prevents you from fooling yourself it's finished when there are only a few little details to tidy up. I had to be REALLY disciplined to finish every little aspect before moving on . As I said I'm even converted to the idea of doing the face first now.
Andy.
Thanks Andy-you should give it a go! Face your fears and slay the demon! The more you do it the less terrifying it will be ;)
He looks great Neil. Nice colourful figure, and the fresh faced tones are excellent. Face first is the way I’ve worked for many years. It always spurs me on to do the rest. Interesting how figure painters always end up with their own painting sequence though. There is no “right” way to do figures, just the way that works for you....
Well here’s a 'Rave from the Grave'!
I last posted on this project over five years ago...and I started it SIX years ago!
I resurrected this project as a diversion because I just haven’t been able to knuckle down to the GIs lately, neither for D-Day nor Iwo Jima. As with the other two sets in the box (German and British) there are four figures in the set and the other three were all partially started. I didn’t bother with any WIP shots as it’s basically just more of the same.
The only major headache was removing the bayonets from the sprue; they all have a sprue gate half-way along the length of them which makes it very difficult to remove them without breaking them. I actually have another set of these figures and I went through all of the bayonets in that and I still ended up making a digital one and 3D printing several - in case of subsequent accidents.
I should also point out that I’ve learned a lot about painting in the intervening years. Although there doesn’t seem to be much visible improvement in the results, I can say I find the process much less stressful, and possibly even enjoyable....
Anyway, here are the rest of the gang.
Figure B
Figure C
And the Officer is in the next post
Finishing this was a bit of a chore, but it’s been hanging around for six years so it had to be done.
This is the inspiration for the base
I started with a similar base to the other two sets and filled it with SculptaMold, mixed with a dark wood stain to avoid having white patches show through the paint .
It’s not really strong enough to hold the figures upright, so I added some wood blocks first to pin them into
When it was dry it looked like this- better than white, but not what I wanted.
Next time I will use paint,as the wood stain is clearly not saturated enough.So I sprayed it brown and added some static grass, which looked terrible so I didn’t take a pic.
I had always intended to use this PE foliage from ScaleLink,
so I sprayed it dark green
and then worked into it with some brighter green
Then came the fun part of twisting them all to look vaguely realistic.
I added some fallen leaves to the ground before I planted the ‘brambles’. I collected these a couple of years ago but this is the first time I have used them, they are from birch catkins.
I get them all over my garden in the autumn from my neighbour’s tree-he has no idea that it helps my hobby.
So here’s a taster and I’ll put the rest in another post
Here are the finished shots- could have done with a bit of dust on the boots .Oh well, never mind, I need to get on with them GIs
French WWI  Infantry (1).webpFrench WWI  Infantry (2).webpFrench WWI  Infantry (3).webpFrench WWI  Infantry (4).webpFrench WWI  Infantry (5).webpFrench WWI  Infantry (6).webpFrench WWI  Infantry (7).webpFrench WWI  Infantry (8).webpFrench WWI  Infantry (9).webp
