Now before I started this project I knew almost nothing about Japanese tanks. There’s still an awful lot that that I don’t know…
However, having looked at a lot of on-line images of the Ha-Go I noticed one aspect of the tanks used in Malaya - or at least in the Bakri action - which differs from most other Type 95s: at least some of them have a large rectangular box on the rear port trackguard which sits behind the standard metal bin. Once I started to assemble the kits (both the Fine Molds and Dragon ones are the same in this respect) this began to puzzle me, because this box is in the same position as the jack and other tools, all of which have specific mounting points which would otherwise be in the way of this box.
The clearest view of this box is that on the second tank (shown in the lower image and in the background of the one above). Even though it is partially destroyed, it is possible to see how it overhangs the track guards thermselves and was held on the vehicle by a length of wire or rope. As for what the box contains I have no idea. It also appears to be of fairly flimsy construction - so perhaps made of thin wood or even cardboard.
Also visible in the same image is the wrecking bar (with a length of chain wrapped around it) and mounts for the other tools which were mounted on the side of the engine compartment - and not the track guards - which would explain how the box was able to be placed in this position. What happened to the jack, I have no idea.
The only other Ha-Go I have come across which has a tool layout which is in any way similar to the Bakri tanks is the one in Bovington Tank Museum. I believe this Type 95 was captured in Burma. It was later examined in Calcutta before being sent to Britain.
This Ha-Go, which appears to be in good condition, still has one smaller box behind the official stowage bin, although on capture it clearly had yet another as well. It also has no mounting point for the jack and you can see the clamps for the other tools (crowbar, spade and pick) on the front port trackguard - so a third variant.
By the way, there is a great walkaround of this tank from the museum’s curator David Willey at:
Tank Chats #50 Ha-Go | The Tank Museum - YouTube 1
The tank is sealed, by the way, because of the asbestos which is still inside it and, as he helpfully explains, the camouflage scheme is completely spurious.
So I replicated the tool clamps from spare photo etch and made a crowbar from a piece of metal rod with the ends sanded to a suitable profile. You can see my attempt at scratch-building the box from thin plastic card in the images of the model below, in its finished state state prior to painting.
Oh yes, one last word on the tracks. The Fine Molds kit comes with the link and length variety, which are OK, but lacking in detail. The Dragon kit comes with the ‘rubber’ full-length type, which some people love and others loath. I have so say, they look very nice detail-wise and the only issue would be getting the right sag.
So I went for the Friul model option. Now I have heard from a few people that the quaility at Friul may be slipping and I have to say these ones bear that out. Not only was there quite heavy metal flash on many of the links, my box also came with two port sided pairs.
