Dedication or mad ! Great work .On to the engine. I figure the spark plugs would have been pilfered almost right away, but looking at photos of the HL62 engine, where were they? I couldn’t find them, but it turns out they’re under a bit of sheet metal that sits over the inlet ports and spark plugs, meaning I had to do a fair bit of carving.
I forgot to take a photo of the engine before I began doing this, so here is one I found on Armorama:
It’s the part on the right, the right side of the engine. After judicious carving, scraping, filing and chiselling, this is what I ended up with so far:
It still needs a little more work, and after taking the photo I put some liquid cement over all of the cut area to get rid of the scars. Those are more obvious here than on the part in the flesh, because of the close-up. The actual part is only about 3 or 4 cm long.
I need to finish this bit before I can even really start on the mad part about the engine …Dedication or mad ! Great work .
Thanks, though there are a bunch of people on here who could do this much more neatly than I canQuality workmanship there Jakko, very nicely done![]()
I wish I had clearer photos, though. The load bed is bugging me, some things are off about it compared to both the model and drawings and pictures of preserved vehicles, but I can’t put my finger on what it isTenacious researching too![]()
Thanks, it’s getting there, though not as easily as I would like …Looking great the detailing and modifying is really paying off.
How about "Madly Dedicated"!!! :tongue-out3:Dedication or mad ! Great work .
It's beginning to look that way :smiling:How about "Madly Dedicated"!!!
I wouldn’t have done this if the valve cover had still been in place in the photo of the real vehicleMost people reckon they tart up the engine with a few wires and cables. This is the first time I've seen someone build its insides :hugging-face:
Actually far simpler than I had anticipated. The most complex part was the bits of plastic that sit over the camshaft: I filed a notch into the end of a piece 3×1 mm of plastic strip, then cut it to length (about 1.5 mm) and repeated that five more times, plus a piece of unnotched strip at the end. All the rest is pretty straightforward, just simple bits of plastic rod and strip. Though I must say that if you intend to do this kind of work, a chopper tool makes your life a lot easier.Very impressive scratching.
Yes, that’s the part I haven’t figured out yet. They are a fairly complicated, curved shape so I need to find a way to make twelve of those without too much effort, and so that they fit over the shafts I already glued on too.good luck with the rocker arms
