Sd.Kfz. 7 half-track, post-war
Really excellent detail work on display here Jakko.
Great work jakko , the additions really lift this , cheers tony
Thanks, the fun part of building a model of a real vehicle is always those little bits you have to add or change that make it more than just another kit, I think.
On to the engine. I figure the spark plugs would have been pilfered almost right away, but looking at photos of the HL62 engine, where were they? I couldn’t find them, but it turns out they’re under a bit of sheet metal that sits over the inlet ports and spark plugs, meaning I had to do a fair bit of carving.
I forgot to take a photo of the engine before I began doing this, so here is one I found on Armorama:
It’s the part on the right, the right side of the engine. After judicious carving, scraping, filing and chiselling, this is what I ended up with so far:
It still needs a little more work, and after taking the photo I put some liquid cement over all of the cut area to get rid of the scars. Those are more obvious here than on the part in the flesh, because of the close-up. The actual part is only about 3 or 4 cm long.
Dedication or mad ! Great work .
Quality workmanship there Jakko, very nicely done :)
Tenacious researching too ;)
Excellent stuff all round !!
Andy
I need to finish this bit before I can even really start on the mad part about the engine … :)
Thanks, though there are a bunch of people on here who could do this much more neatly than I can :)
I wish I had clearer photos, though. The load bed is bugging me, some things are off about it compared to both the model and drawings and pictures of preserved vehicles, but I can’t put my finger on what it is :(
Looking great the detailing and modifying is really paying off.
Thanks, it’s getting there, though not as easily as I would like …
Hi Jakko
Always interesting to see what you're up to. Cleaning up 'styrene surgery' with liquid cement works a treat.
On the right side of the engine, below the ports for the spark plugs, the real engine has a sharp ledge that the sheet metal cover sits against. To make it, I carefully sawed a slot through the inlet pipes and glued in a piece of plastic strip:
And I also drilled holes for the spark plugs themselves, making it clearer (I hope) that there are parts missing here. The mounting for the carburettor is also in place, but I cut the carburettor itself off and drilled two holes into the top of the mounting (not visible here) as the inlet pipes.
Now, I mentioned to Mr. Race that I needed to finish this before I would get to the mad part …
If you look very closely at the first photo of the real vehicle I posted, you may notice that the valve cover is missing. I’m puzzled about the reason for this, as in the earlier picture (where the front is on bricks) it’s still in place, but because it’s missing in the picture I’m using as a guide, I need to build the valve mechanism …
I began by cutting the top out of the engine. Dragon has the valve cover as a separate piece, but the top of the engine below it as a flat plate, which I cut out before glueing the two engine halves together. Then I put in a piece of plastic card as the top of the cylinder head, a cog from a punched disc with teeth sawn into it, a camshaft and various other bits I could see in a photo of a disassembled, real engine on page 80 of the Nuts & Bolts book about the Sd.Kfz. 7.
The holes are for pieces of plastic rod that will represent the valve stems and springs:
This picture also shows the shafts for the rocker arms and more pieces of plastic strip between them to fill the gap.
Now to find a way to build the rocker arms themselves …
Hi Jakko
How about "Madly Dedicated"!!!
It's beginning to look that way :smiling:
Most people reckon they tart up the engine with a few wires and cables. This is the first time I've seen someone build its insides :hugging-face:
Very impressive scratching.
Mental jakko , but in a good way ! The scratchbuilt internals look excellent , good luck with the rocker arms Cheers tony
I wouldn’t have done this if the valve cover had still been in place in the photo of the real vehicle :) Initially, I thought the whole cylinder head had been removed, which would actually have made this job easier: I would only have needed to put six holes for cylinders into a cut-down engine.
Actually far simpler than I had anticipated. The most complex part was the bits of plastic that sit over the camshaft: I filed a notch into the end of a piece 3×1 mm of plastic strip, then cut it to length (about 1.5 mm) and repeated that five more times, plus a piece of unnotched strip at the end. All the rest is pretty straightforward, just simple bits of plastic rod and strip. Though I must say that if you intend to do this kind of work, a chopper tool makes your life a lot easier.
Yes, that’s the part I haven’t figured out yet. They are a fairly complicated, curved shape so I need to find a way to make twelve of those without too much effort, and so that they fit over the shafts I already glued on too.
There`s white Witchcraft,there`s Black Witchcraft...... and then there`s MOGELLIN` WITCHCRAFT :dizzy:!!!!
Not so long ago you would have been either Burnt at the stake or Hung for that Jakko ;)!!
Lovin` it!!:cool:
Andy
That's some excellent work on the engine there Jakko.
Nick
Thanks, guys, though I assure you it’s nowhere near as difficult as it may seem. The carving out of the recesses for the spark plugs was the hardest part, and not one I intend to do again soon :) The difficulty of the rest lies mainly in figuring out what is there on the real thing and coming up with a way to build it.
As I’ve not worked out how to make the rocker arms, I went back to other parts of the model. Under the load bed, I added bolts, strips etc. as well as a replacement spare wheel carrier, because Dragon’s part is far too large:
The bolts etc. are only on this side, because the side panel will be hanging down on the other so they won’t be visible there.
The other part is a small fuel tank that sits under the dashboard. Dragon omitted this, but did include one for earlier versions of the Sd.Kfz. 7. By fitting that back to front, with the tap moved to the other side, plugging the opening with plastic card and adding a plastic strip retaining strap, it looks the part.
Inside the cab, I put in the battery box:
This is nearly all 0.25 mm card and strip, the whole thing is 14 mm long and 8 mm wide. The cables inside are copper wire with rings punched from plastic card, and though they’re complete conjecture, I think they look convincing enough.
