It was actually a combination of that photo, the pictures in the Nuts & Bolts and Wings & Wheels books on the Sd.Kfz. 7 (which only show the assembled suspension) and looking at the kit partsTen out of ten for finding and interpreting that old photo. Same score for the inventive build :smiling: :thumb2:
Somehow, I suspect that never happened before the scrap metal merchant took the remains awayEngine is looking good but it's gonna need an expensive rebuild to get it running :rolling:
They did liberate the whole wheels. The Sd.Kfz. 7 has four rows of roadwheels on each side: an outer row on the even-numbered axles, two rows on the odd-numbered ones, and then an inner row on the even ones again. On the stripped vehicle, the outer row was missing. My guess is they ended up under someone’s cart.I have a question; How the hell did they steal the tyres off the wheels? Surely it would have been easier to knick the whole wheel!?
Get to the mad part ! Your way past that Jakko. Love the way you use a photo and really represent this in scale . That's a great way to model true life like you do.On the right side of the engine, below the ports for the spark plugs, the real engine has a sharp ledge that the sheet metal cover sits against. To make it, I carefully sawed a slot through the inlet pipes and glued in a piece of plastic strip:
And I also drilled holes for the spark plugs themselves, making it clearer (I hope) that there are parts missing here. The mounting for the carburettor is also in place, but I cut the carburettor itself off and drilled two holes into the top of the mounting (not visible here) as the inlet pipes.
Now, I mentioned to Mr. Race that I needed to finish this before I would get to the mad part …
If you look very closely at the first photo of the real vehicle I posted, you may notice that the valve cover is missing. I’m puzzled about the reason for this, as in the earlier picture (where the front is on bricks) it’s still in place, but because it’s missing in the picture I’m using as a guide, I need to build the valve mechanism …
I began by cutting the top out of the engine. Dragon has the valve cover as a separate piece, but the top of the engine below it as a flat plate, which I cut out before glueing the two engine halves together. Then I put in a piece of plastic card as the top of the cylinder head, a cog from a punched disc with teeth sawn into it, a camshaft and various other bits I could see in a photo of a disassembled, real engine on page 80 of the Nuts & Bolts book about the Sd.Kfz. 7.
The holes are for pieces of plastic rod that will represent the valve stems and springs:
This picture also shows the shafts for the rocker arms and more pieces of plastic strip between them to fill the gap.
Now to find a way to build the rocker arms themselves …
There’s a lot of satisfaction in building a model of an actual vehicle, I think. But there’s also the down side that once you’re done, you will start seeing things you missed …Love the way you use a photo and really represent this in scale . That's a great way to model true life like you do.
Oh, I have been for a long time. There’s no cure, you knowBut you are Mad :smiling::nerd:
You've done a splendid job , a pleasure to follow .There’s a lot of satisfaction in building a model of an actual vehicle, I think. But there’s also the down side that once you’re done, you will start seeing things you missed …
Oh, I have been for a long time. There’s no cure, you know :smiling3:
Sorry I did not make myself clear. lol I was referring to the front wheels where the actual wheel is there, good job on the rims by the way, but they have made off with just the tyres...They did liberate the whole wheels.
