When you consider Colin along with the pump 90 W there is the UV clarifier 15 W , an air stone pump another 90 W all running 24 / 7 it soon mounts up .
I can see the birds like in those gym videos of people falling from fast treadmills. :smiling6:Had to buy a new pond filter pump , the old one was 7 years old and has run none stop , don't think that's bad .
New pump is in, much bigger output , far more than I need apart from the length the back flush hose is from the pump .When I fitted this one up I upgraded to pipe size to 40 mm , wow , some difference in the volume of water coming back down the return from the filter housing . Glad this one has a variable out put or the birds would be unable to have a bath as they would be swept into the pond !
That’s only as much as two 100 watt light bulbs John, hardly excessive consumption, and if you’ve turned the flow rate down it will be even less. What’s the string for, by the way?When you consider Colin along with the pump 90 W there is the UV clarifier 15 W , an air stone pump another 90 W all running 24 / 7 it soon mounts up .
Ah, right. I just sit ours on a brick and pull it up by the outlet pipe. Weirdly it doesn’t have a filter……big outer mesh casing with nothing inside except the pump mechanism. The pump and pond came with the house so I thought the filter had been misplaced by the previous occupants. Checked on line, and that model of pump appears not to have a filter at all. Doesn’t bother the newts though, we get our share, along with plenty of other pond life :smiling5:Morning Tim, the string is to allow me to get the pump out for cleaning and to keep it off the base of the pond. If the pump sits on the bottom there is more chance of it having Newts try to get inside, even with the reduced mesh. Not bothered really about the electric usage as our panels in this sunny period produce more than we use each week. Unfortunately not so in the winter :crying:
Turn it into a bog garden.Belinda gave up on her pond years ago so I told her this year I’m filling it with dirt and planting flowers I’m tired of the nasty leaves in it.
Indeed. I think we have similar set ups. Which reminds me, I'm off to ebay, I need new UV tubes.When you consider Colin along with the pump 90 W there is the UV clarifier 15 W , an air stone pump another 90 W all running 24 / 7 it soon mounts up .
That’s a good idea Colin I just might do that Frogs like it when it’s not full of leaves anyway.Turn it into a bog garden.
Completely agree Jim. i think they are almost jewel like.Hi John
Beautiful weather here as well. Gave the car a good clean.
When seen close up in the sunshine starlings are beautiful - I think iridescent is the right word.
Unfortunately they will take any meat they can get Ian. They are major predators of songbird nests, as are woodpeckers :disappointed2: It’s one of the reasons decent nest boxes have a metal ring around the entrance….Well here it is cold, windy and wet. So much for summer!
The birds in your garden are very tame and used to people. We have tons of birds in the garden but they scatter as soon as you go out. Some come back though.
We have a magpie problem at the moment. Surprised how bold they can be! They chase our outside cats away and take the food from them! Also had the dubious pleasure of watching one rip a rather large rat(?) apart to feed its young! I don't know if he caught and killed it or if it was road kill but the woman next door said that she saw it swoop down from a tree and then fly of with it!!
Have also stopped one from taking a black bird young that was very much alive. I know they take dead things but live prey?
Ian .Well here it is cold, windy and wet. So much for summer!
