OK, we’ve moved on a touch……
Stripes are done…….
Here are the legs of the Zebra……..
….and here is the airframe……no bleed or overspray so I’m well chuffed…..mind you…
It took this much masking tape……
There are decals in the kit, but I went with the mask and spray because I thought it would look better….. As an aside, Airfix helpfully give dimensions for the stripes on the decal and painting sheet.
Trouble is, they say each wing stripe set covers 135mm…..with stripes about an inch wide…….and they are about one fifth of the wingspan over all. The model wingspan is just over 200mm….wtf? Dimensions taken from the 1/24 version Perhaps? I just took dimensions from the decals
Anyway, just the prop tips and leading edge yellow and I’m up to detail painting and varnishing…..
See you soon…..
Stripes are done…….
See you soon…..
