A Phantom for Halloween
Geoffers
Hello Chaps,
Well I’ve finished one GB and am about to wrap up my Mossie build so time for something new.
What better for Halloween than a Phantom, in this case an Airfix 1/72 Phantom FG.1
I’ve had this in the stash since last Christmas, it was a gift from my youngest son so thought it about time I built it.
Pictures:
The usual single bagful of sprues.
Two nice schemes to choose from “Black Mike” of 111 squadron or a classic scheme from 43 squadron.
And a few stencils to look forward to :astonished:
I’m starting tonight once the trick or treaters have finished knocking the door so an update soon.
Thanks for looking :thumb2:
Geoff.
Those stencils will drive you myopic at 1/72…….it will look great when finished though…..
Looks a nice kit Geoff!!! As a kid, F-4's used to fly over my house, and I loved them too. Now a bit advice if I may...If the stencils start driving you bonkers, wrap the kit carefully and send it to Tony (yakface). He loves to stick 'em on and the more there are, the happier he is!!!...
Allen
A great choice and these 1/72 Airfix kits are usually very good. As for those stencils - you have to question the sanity of that many at this scale :rolling:
The are only about 300 stencil posts on a spook and weapons load out. Lol.
Oh a spook. Nice one.
Cheers Ian :thumb2:
Fingers crossed Tim :smiling3:
Allen
I’ll bear it in mind Allen :tears-of-joy:
Hopefully Ian :smiling3:
I’m sure I’ll be questioning my own sanity Jim when it comes to applying them :tears-of-joy:
Should keep me out of trouble for a while or drive me crazy :tongue-out3: Ian.
Geoff.
Look forward to seeing this one come together, I once got to fly a Phantom simulator as a birthday present once.
Hello chaps,
Despite not posting any updates for a while I have been pottering away with the build.
Unsurprisingly the cockpit was first up which comes as a tub with various panels to be glued in, a few decals to pop into place before the seats are added.
So here is the cockpit all painted up using various Vallejo Model Air paints and a basic bit of weathering using Tamiya Panel line wash.
I’ve painted all the other internal bits and bobs such as intakes and engine parts so the next stage is to add the cockpit and join the fuselage together.
Hopefully another update soon, thanks for looking :thumb2:
Geoff.
Hello chaps,
Slow progress so far due to limited bench time but I’ve managed to get a bit more done.
With the cockpit finished it was time to bring the two fuselage halves together.
The spine comes as a separate piece which helps eliminate any nasty seam line down the centre.
The fit was generally good but I made sure I took time to glue it down a bit at a time.
The jet exhausts haven’t been fixed in place at this stage. The actual placement is a bit vague so I’m leaving them loose until the fuselage underside is fitted.
The aforementioned underside ready to be cemented into place.
A lot of the ancillary parts have been primed.
A bit more work to go but I’m really enjoying the build so far.
Geoff.
Hello chaps,
Seems like Halloween was a good time to start this build as so far it’s been a bit of a devil :confused:
The underside plate has been added but I really struggled to get it all to fit in place properly. I think it may have been slightly warped which meant lots of clamping to get it anything near a reasonable fit.
Unfortunately it seems that this has made the air intake covers trickery to fit. Some filler will be required despite some fettling.
I’ve also added the wing tip’s which come as separate parts. There is a bit of a step where it joins but I’m not sure if this is correct. I’ve looked at a few reference photos and checked out a couple of builds on YouTube but can’t find any reference to it :confused:
I’m putting this build on the back burner for a short time now while I start my Emergency Services Group Build entry.
Thanks for looking
Geoff.
Looking good Geoff. Having the separate fin along the spine is good. That large, flat underside is probably prone to a slight twist but you seem to have it nicely in place. Intake covers fit issue looks straightforward to fix.
Cheers Jim, yes all fixable thankfully.
I wasn’t expecting any issues with it though as the few builds I’ve watched/read made no mention of any problems :thinking:
Geoff.
Hello Chaps,
Well this has been sitting on the “shelf of doom” glaring at me for far too long now so time to get it finished 🤔
The fuselage has had some photo etch added, mainly to the wheel wells and also the jet intakes.
I found that the original canopy had a crack running down the centre of it. I could have gone for the open option but wanted a closed canopy, fortunately the kind people at Airfix sent me a replacement clear frame 😊.
This has been masked and apart from a bit more pe work it is ready for primer.
Hopefully another update soon 🤞
Thanks for looking 👍
Geoff.
Nice work Geoff. There is just something about the shape of the Phantom which makes it so right. A great looking aircraft.
