Scotties big Zundapp
Just had a catch up paul , gobsmackingly good work here. Your fabricating skills and eye for detail are next level , brilliant stuff , cheers tony
I would say not for a mild steel system operating in very challenging conditions. I would expect some heat blueing on the outlet exhaust downpipes though.
Thanks Tim for the feedback, I will darken that area down a bit.
I agree with Tim, the exhaust is probably not over-rusted if the bike has been used for a fair while. Maybe a bit dark in colour — I remember the rusted parts of the exhaust of my moped 30+ years ago being more of a tan-grey, but other than that, IMHO it looks very convincing.
Jakko thanks for that I will grey it down a bit I will try some thinned down Valleyo smoke.
Work continues on the forks and handlebars. The very basic brake and clutch levers were chopped up and modified to remove the solid look. they still need a bit of cleaning up.
Next some bolt details were added to the yoke< hopefully some of the bike builders riders will put me right on the correct term.
cheers
Scottie
I've been doing a bit of work on my Land Rover's exhaust, which gets used off road & it is pretty similar. The look you have is about right for one that been in use in difficult conditions for a while. It's all looking good Paul.
Thanks for that Graeme appreciate the feedback.
well it's starting to look like a bike.
Front forks assembled and added but prior to that the decal with the manufacturers badge on it was added. this was first applied to a thin piece of evergreen to give the badge a bit of depth.
added a bit of heat staining to the exhaust could probably do with a bit more but will do this when the detailing takes place.
cheers
Scottie
Going along great Paul. Detail is top drawer. Funny how the exhaust looks on a clean frame though…..like someone has used old parts on a new bike…
Tim,
Your right it does look strange I think I need to tone down the exhaust a tad but, the frame will look older when I have finished.
Looking good.
Thanks Mark
Tim,
Thanks Mark
Tone down the frame first :thumb2: The bike probably just needs a bit of dust to tie them together once you have…..
I have continued detailing some of the smaller parts. I am waiting for some brass rod before I can start on the linkages.
The riders foot rest has been cleaned up and a bolt head added.
The pillion passenger footrest has also been detailed with bolt head detail plus the pivot pin and finally the foot peg was drilled out and a piece of tube added.
Finally for today the fuel tap and pipe work was tweaked. the plastic replaced with wire and plastic tube and the fuel tap made from copper wire.
cheers
Scottie
