A Different Direction..............
If it does turn out to be the power supply Dave, let me know the voltage and current. I have a few here.
Given up on this for the weekend - started off in the wrong frame of mind this morning & just got more annoyed as I went on.
New week - new enthusiasm - I hope
Good idea to take a step away for a while Dave. ;)
..... You'll come back to it,refreshed and with a new approach, then you'll crack it in no time :)
Well, It's working!!!!!!!!!!!!!!
I wish I could say I found the fault & corrected it - well, I corrected it, whatever it was. I unplugged every plug, took off all the power connections ( yes I did check that the 230/120 switch was in the correct position - it was ). I cut off the ends of the mains wires stripped off the insulation & made new connections. The plugs were all replaced, making sure that they were all seated. Then - power on - fans started, the display came on, and to my surprise it beeped! ( wasn't expecting that! ). I then stupidly turned the printer round & gave myself a nasty AC shock - that'll be one of the first things I'm going to modify. The axes all moved smoothly, no graunching sounds, and it Auto-homed without crashing into the build plate.
I've got to go out for a memorial, so I won't actually be able print anything, but the whole evening awaits!
Relieved Dave
Lychee's new version of its slicer has anet settings for filament printers if you are still looking for a new ''cura''
Don't pick too tall a print for the first one. You'll be waiting hours for it to finish :tears-of-joy: I usually run prints overnight anyway, but obviously you want to check it's running properly.
If the manufacturer supplies one or recommends one I would use that ,and any recommended settings because it will have been optimised already.
best of luck
best of luck
I've looked at the Anet supplied models - one is a plaque with chinese characters, and the other seems to be a sort of michelin man! I'll give those a miss!
Thanks for that Gary, I'll take a look
I am pleased you've sorted it. I'm sure the gremlins have had their fun and all will be good now.
I spent an hour or so last night 'levelling' the build plate, which seems simple in theory, but in practice is rather tricky. Eventually I got it right - then started to print - ha! The model just wouldn't stick! It would lay down a layer or two, then it would start dragging it around. I had several attempts. I was using PLA, at 200C Nozzle & 60C bed temperatures. This was the PLA supplied with the printer, and I've come to the conclusion it's rubbish!
I'm busy this morning, but this afternoon, or evening, I'll open a brand new 1kg spool of PLA filament & hopefully have a bit more success. I do know now, that all the bits work, the printer reads from the micro SD card, and responds to the gcode file, heating the nozzle & build plate to the right temperatures & extruding filament & making the appropriate movements - now all I have to do is make it stick! I have got a magnetic build plate coming, I don't like the tape style, it seems rather hit and miss
You could try hairspray Dave if the build plate is removable. Or pritt stick.
Be sure you don't have a tail of filament sticking up which catches the nozzle and rips the layers off
Do you have the fan(s) set correctly? They are designed to cool down the printed filament, maybe the first layers are still too warm
Another tweak is the print speed, if you slow that down a bit it might give the first layers time to stick.
I've always said you need to be a tinkerer to get on with 3D printing....
It's a challenge right enough. Success is but a breath away though :thumb2:
There are so many settings in the slicer, that can affect adhesion, just a matter of getting the right combination - as you say - tinkering............
Just caught up with this. Exciting stuff.
I feel your frustration Dave but this always tends to be the case with new technology. You'll get there.
Don’t know much about this process, but Neil’s tips sound worthwhile and your persistence is exemplary.
