Tamiya Wespe 1/35 scale.
You're lucky the tops came off those oil paints John. None of my old paints are usable although they feel quite squashy, I can't get the tops off the tubes!
Pete, I tried one and it was stuck fast , however the old trick of putting them screw top down into warm water soon worked . Give that a try if you not done so.
Just cut the blunt end off and reseal it with a bulldog clip Pete. They stay usable for very many years…..
Further weathering .
Tomorrow the base, for me the best part.
Thanks for looking in.
John.
Tried hot water, then white spirit (or it might have been turps) then threw them in the bin!
Looks so good John I like how the Camo blends this is one of my favorites of the Camos you’ve done. Carry on Commander Race.
Arh many thanks Lee, wanted this to look soft, did it this time with out the black Panzer Putty.
Ooh John that's looking good!
Many thanks Neil.
Loving it John!! Top notch work!!
Very well done so far.
Cheers Andrew.
Morning John,
Great job with the camo and weathering….looking very good :thumb2:
Hi Si, good of you to look in . Hope your all well .
That weathering is very realistic. Well done. Oils are great for this kind of work.
excellent stuff John, this is getting better and better each time i see it... :thumb2:
Steve's oil work is superb. It shows that you don't need all the latest weathering stuff to get great results.
