Thought I'd do a review for this, firstly Mike " is it me " aka wibble sent it to me to ask what I thought of it. I was thrilled to see a quick and easy to use tool .:anguished:
He agreed with me a review was in order. He found it to be hard to assemble and use. That I'm not the least surprised !
First thing why call it a graver, I'd call it an engraver !
The box , a U tube video that is accessed by scanning the code on the box lid . Like all advertising instructions, it makes it look easy.:smiling3:
This what you get in the box, a holder, It has 2 threaded threads fixed with a hex nut.
2 pieces of resin plastic to widen the cut lines , one for the brick length and the other for the line.
The blades are laid in that recess to the right lower
The blades are laid in that recess to the right lower.
It appears you have to build up the blades allowing one to each recess With that done the legs are pushed together and the bolt inserted and into the nut and tightened up .However I noticed that there was gaps in the holder, not on every one but on some. Trying to get the blades to then line up was a night mare. Eventually I managed it, agree with Mike saying you need 20 fingers and a third hand.
On the U tube and on the web site it shows another set of blades for the 1/72/48 version. They appear to have holes in for the bolts to pass through, needed here on the 1/35 as well .
A piece of exp foam was then marked with the full amount of blades, very light passes are needed. At this point both bolts were fully tightened but.
This happened, the blades moved in the holder when any pressure was applied. In fact one blade came completely out of the holder.
By this time I had started to mark out the width of the brick. Just to see how my method work as a comparison .
I found it just as quick to do it line by line.
This the Liang methods to increase the line width, I use a very thin putty , filler knife, long and far more effective.
Below is my method, at the bottom is the Liang
To be fair I played with set up for some time, with the blades not being held in place with any mechanical fixing like a blot and nut it was hit and miss. The blades tended to splay apart, esp the outer one.
Some people may get on with this, suspect most won't . A shame as drawing one line at the time is slow and I thought this method would save marking out and would be quicker.
Not for me.
Hope this has been of some help, no doubt I could keep trying as practice does help , but in this case not for me.
The blades are laid in that recess to the right lower.It appears you have to build up the blades allowing one to each recess With that done the legs are pushed together and the bolt inserted and into the nut and tightened up .However I noticed that there was gaps in the holder, not on every one but on some. Trying to get the blades to then line up was a night mare. Eventually I managed it, agree with Mike saying you need 20 fingers and a third hand.
This the Liang methods to increase the line width, I use a very thin putty , filler knife, long and far more effective.Below is my method, at the bottom is the Liang
Not for me.
