I have a similar sight sitting on my workbenchAnd AFV's AVRE awaiting paint.
Will you be adding the actual fascine?
Whilst I also love his work, because he's so popular and uses so many different techniques, if one does something in a similar way it's automatically assumed that you're copying him.I thought the method Nightshift does on his groundwork was what all diorama builders do.
Very true Andy, basically what he's doing is what's been done for donkey years by others just that he's actually physically showing it on video how it's done making it look so easy. He has talent for sure and knows painting skills. Good thing he tells it's not done in real time...it takes a while. I like his short cuts and importance of a well made base finish with wood veneer and double sided tape.Whilst I also love his work, because he's so popular and uses so many different techniques, if one does something in a similar way it's automatically assumed that you're copying him.
I'd give a limb for a fraction of his talent, vision and dedication though :smiling5:
Thanks John.Keep going Jack, looks a great dio .Full of detail .Love Night Shifts methods and site. Always makes me laugh with his comments.
I'm not sure really. I've not got an idea for the finished product yet.I have a similar sight sitting on my workbench :smiling3: And I notice you also didn’t feel like cleaning up the engine deck hatch stays.
Hi Jack, tracks are also not my favorite but once they're on the fun begins getting them to sag and fit the terrain and weathered. So keep going.A little diorama on the go, lost mojo on the tracks though.
View attachment 483892View attachment 483893
The fascine would certainly make it more eye-catching. Can’t be too hard to build, tie suitably sized twigs into bundles and then tie those bundles around two or three pieces of plastic (or other) tube. I’ve got approximate dimensions of the real thing in a book somewhere if you want themI'm not sure really. I've not got an idea for the finished product yet.
Thanks Jakko. The instructions give dimensions (assuming they are correct). I was actually thinking it might be a little more difficult finding appropriately scaled, straightish twigs. Going to have a look when out walking the dog. Certainly nothing suitable in my garden.The fascine would certainly make it more eye-catching. Can’t be too hard to build, tie suitably sized twigs into bundles and then tie those bundles around two or three pieces of plastic (or other) tube. I’ve got approximate dimensions of the real thing in a book somewhere if you want them :smiling3:
Oh yeah, that’s right, they do, I forgot about that. (I also have this kit, but built it without the fascine carrier.)The instructions give dimensions (assuming they are correct).
Those dimensions in 1:35 would be around 105–120 mm long and 70 mm diameter, so AFV Club’s suggested size is close enough.The Funnies said:It was originally intended that fascines would be formed from rolls of chestnut paling but the 79th Armoured Division, during the N.W. Europe campaign, obtained most of their fascines from local sources and usually these were made of brushwood faggots between 12 to 14 feet long which were bound together to form fascines about 8 feet in diameter. It was quite common for fascines to be formed around three or four lengths of piping (normally of corrugated steel sheet) which not only reduced the weight of the fascine but also provided a freeway for any for of water there might be in the ditch in which it was to be placed.
That’s probably going to be the main issue, yes.I was actually thinking it might be a little more difficult finding appropriately scaled, straightish twigs.
Actually Rick there are millions of little stencils all over wingy things. On a BF109E for instance there's a number on each frame of the fuselage, and at 1-72 they are about 1mm tall.Tried this once and failed miserably........so EF it!!! Yours are the Bomb!!! Oh, just a thought......unless the wingy guys are modeling in 1-87 their decals are WAY bigger than these!!! You get "all" the Kudos Paul! :thumb2: :thumb2:
One word: mudI guess you can't really leave off a number plate and get away with it, can you?
His use of veneer for the sides is interesting. I checked some of the prices, lots of types in the types on offer.Very true Andy, basically what he's doing is what's been done for donkey years by others just that he's actually physically showing it on video how it's done making it look so easy. He has talent for sure and knows painting skills. Good thing he tells it's not done in real time...it takes a while. I like his short cuts and importance of a well made base finish with wood veneer and double sided tape.
Wabble
| Qty From | Qty To | Unit Price |
| 1 | £18.90 | |
| 2 | 4 | £17.80 |
| 5 | 9 | £16.50 |
| 10 | 19 | £15.90 |
| 20 | ∞ | £14.80 |
I've got 16 BA here, about 0,35mm if that's any use...I wanted to thread them, but found my tap & die set didn't go down to 0.6mm size, only 4mm...P
