What's on the Bench 2023
I have so much going on at the table an the moment, I forget what I'm doing sometimes. Hot weather has also put a damper on a lot of things. I have managed to make some progress on the gas station through it all,
Wheels are ready for paint, as is the main tank/frame too. I added the the hex nuts and bolts on the strap holders. I wanted to thread them, but found my tap & die set didn't go down to 0.6mm size, only 4mm...Pump handle and pump is painted and the support cables added using 0.01 rigging from MIG. The most fun was threading it through the brass tubing........NOT!!!...........It's getting there....
Allen
ooh yum!
Thanks guys! I've hairy sticked the wheels and if the wind dies down, I can shoot the rest with the hissy in the morn...
Mom!!!!.....Neil's hungry again.....Can you whip up a few sammiches for him.............
Allen
The Comet diorama is still sighing at me from under its protective cover, but whilst I wait for inspiration I'm knocking together another quick Tamiya kit - a jeep.
I managed to lose a grab handle so I've bodged one out of wire but the rest is going together really well.
Also doing some test spoons of chrome effects for the upcoming truck GB. I've tried stripping the coating from some of the unused parts too but bleach is taking forever so need to find something stronger.
Brake fluid used to work.
.??? Bleach usually takes about thirty minutes, and brake fluid is reputedly much quicker? Seems like the surface is totally sealed. Have you tried scraping through the chrome a little on a sprue (rather than a part) to see if that lets the chemical in to do its work?
Yes Tim. It's a spare part that's not used in the particular version I'm building so I've been pretty brutal with it. The bleach had some effect after a hour. I've sanded the plating from all the edges and even scraped the main surface to try and help it along.
Sanding would be much quicker but there's surface detail I'd lose if I did that.
I fact I've just been and taken a quick snap. All the "damage" is from the bleach or me scraping or sanding. The brake fluid has had no effect after 6 hours now. I'm guessing they've changed it's make up as I remember it stripping real car paint in minutes year ago!
I think I'll just try it overnight in bleach.
That’s a good point. Brake fluid used to be extremely corrosive. If it isn’t these days then the chemical that strips the paint may have been removed. Hydrochloric acid is mentioned in a couple of places. I’ve not used it for this, but if the bleach doesn’t work it might be worth a go. If you do use it, take proper precautions though. Handle it with rubber gloves and wear a respirator. I think you are supposed to dilute in to 25%. Remember, always do what you orter, and add the acid to the water….if you add the water to the acid the water could boil and spray acid everywhere.
And just a thought what about nitromorse the paint stripper I'm sure you can get it in small amounts ,two sorts (or there used to be)one clean up with water the other white spirit ,surprised you've no products at work that would shift it? Dave
I had the same problem with some chromed parts. None of the usual would touch it. Had them in break fluid for ages zip! Turned out that the chrome was dipped in a lacquer of som kind. Bleach took it in fifteen minutes.
Thanks for the advice everyone. It's definitely the wrong kind of brake fluid, or the wrong kind of chrome lol, as I forgot about it last night and it's still the same this morning, 14 hours later :smiling5:
I'll take it to work to dispose of the fluid safely and try something else. Paint stripper is a good shout, just wasn't sure if it would harm the plastic. I also have some oven cleaner liquid, or I'll just be more patient with the bleach.
At least I now know to make it a priority once the GB starts! Previous attempts at stripping Revell chrome took just minutes :thinking:
This is my bench buddy, been sitting in a corner of my cabinet for 18 months and one day he will be finished.
Paints - oils.
I expect that paint stripper would damage the plastic. Since the "chrome" is usually aluminium, I think an alkaline solution such as washing soda would eat it away.
Edit: you could also try Dettol, which worked for me.
