Neil Merryweather
Well-known member
ooh yum!I have so much going on at the table an the moment, I forget what I'm doing sometimes. Hot weather has also put a damper on a lot of things. I have managed to make some progress on the gas station through it all,
Wheels are ready for paint, as is the main tank/frame too. I added the the hex nuts and bolts on the strap holders. I wanted to thread them, but found my tap & die set didn't go down to 0.6mm size, only 4mm...Pump handle and pump is painted and the support cables added using 0.01 rigging from MIG. The most fun was threading it through the brass tubing........NOT!!!...........It's getting there....
Allen
