The Smythemeister's Albatros D.III
The Smythe Meister
Well then,I probably shouldn't be doing this,however,in for a penny...
That's it!! My first ever Bi Plane,and WW1 Plane too!!... It's VERY poor detail wise,well,compared to my recent builds anyway,but I'll give it a go :)
... The paint scheme will certainly be a challenge,(no full decal set provided here!),
But... I'll give it my best shot. ;)
Cheers for now....
Go Mr. Smiff, Go!!! You'll enjoy building it Andy and it will give you a chance to try creating a wood grain pattern on the fusi. But please don't let Cohan do the rigging. You gotta do that yourself Buddy. Happy New Year to you and Rach too!!!...
Allen
Nice one andy , looks detailed enough to me , i reckon some belts is all you need either tape or aftermarket . The painting is where its really going to come alive , a very nice looking scheme , cheers tony
Nice model - these things were pretty simple, so there ain't much detail! The real crunch is getting the wood to look right - It took me quite a few attempts to get it looking anything like...........
There’s a good tutorial (at least used to be) on the Wingnut wings web site for that. You can get decals for it as well.
Most of the tutorials I looked at ( OK, it was in 2020 ) were using oils, I don't have oils, so I used acrylics........
I think the wingnuts how to also used oils. Acrylics should work, but you’d need to add drying retarder to get the correct graining effect I think.
AK3 Dark Sand base coat, then panel definitions added with pencil. Gloss varnish to seal all in, so mistakes can be easily wiped off. Then streaks of thinned Vallejo Natural Wood, then New Wood added, with a small brush - it took me a few attempts, wiping all off & starting again - then sealed in with a gloss varnish tinted with orange
Apologies for jumping in with my process, it just takes a bit of time. I didn't use retarder, the model is small enough for the paint not to dry when adding streaks.
I admit it was an experiment, as I didn't have any oils ( I tried several methods on my guinea pig P-51 before comitting to the real thing ).
The model is actually the Revell reboxing of the Eduard model, that I got at a bargain price ( surprise, surprise ) - I did look at wood decals, but that would hve tripled the total price of the model
'Poor detail', as others have said, it's probably not missing any detail, the aircraft just didn't have any. Most WW1 aircraft are just covered in big sheets. But anyway, what a colourful subject you have chosen here. Nice one.
As much as the 'varnished cabinet' look is in vogue, and an interesting painting exercise, is there much evidence it ever actually happened?
One of the few arguments for is that less paint or covering saved weight, whereas an interesting argument against is the misinterpretation of light coloured fuselages.
However, 'Albatri' models used to be painted yellow, but on period orthochromatic film yellow looks black. So that doesn't add-up either
Many streaky paint techniques go well for props though
Maybe every WW1 German 'plane should just be painted red!
It’s a weight saving device Steve. Unfinished ply would absorb moisture increasing weight and reducing structural strength so it had to be finished. Paints of the time had no varnish content so were varnished afterwards to keep out moisture. Varnished ply would therefore give the same protection, but would weigh significantly less than a painted fuselage because there is no paint there. I read this somewhere, but can’t remember where.
I haven't any evidence per se but there are a lot of colour profiles showing the varnished plywood finish, dating back to the middle of last century! There are modern replicas with this construction
This is a D.Va replica.............
Can't beat an Albatros Andy. So many interesting schemes and techniques to try.
I'm sure you're going to have a lot of fun with it.
Paul
Allen
Hi Allen,the grain will certainly be a challenge.... Cohan took one look and legged it!! ;)
I've found myself a seat.
Nice one Andy,get comfortable mind. . I think this is going to take a while!! :)
Cheers Tony,yes, it'll be belts only on this one...no pilot. ;)
Looks interesting. Great colour scheme. Be good to see what you make of it.
Thanks Tim,I think it's a good looking scheme too.... well,on the box art anyway!! ;)
Hi Andrew.... I certainly hope it will be!! :)
Thanks Dave,yep,sparse indeed!! :)
Nice Andy
Hi Ian,glad to be taking part. :)
...... T.B.C......
