Hot rod Iwatta airbrush
Tim Marlow
Tim
Somerset UK
The recent talk of airbrushes led me to thinking about mine. I have had it for a number of years and actually forgot i had modded it….it is an Iwatta Eclipse SBS because I personally don’t like top feed brushes, they are too clumsy for me…..but…..
I replaced the tail that came with it with this….
It is an Iwatta triple action handle. It replaces the original cut away handle and holds the needle slightly differently.
It enables me to go from that….…..to this…..
In well under 15 seconds……yes, I was sad enough to time it and I certainly wasn’t rushing ;)
Everything that needs cleaning is accessible here. The paint path in the body is totally clear and can be bottle brushed. The nozzle, cap, paint container, and needle protector can be dropped straight into cleaning agent, and the needle can be safely wiped with a fold of tissue moistened with cleaner. This brush has no easily lost seals either….
Assembly is simply a reversal of disassembly and takes about the same time…and the nozzle is big enough to see if the carpet monsters make an appearance….
In addition to this, the handle can be set to give a preset paint delivery for things like mottle camouflage and the needle tail can be pulled clear to give a maximum quick flush while changing colours.
Ah, but how does it spray they cry…..well, it’s an Iwatta, so flawlessly is the answer…..
Here is the pack the new handle came in if anyone is interested….
Any questions, ask away as usual….
Hi Tim
Now that looks very useful. I love Iwata airbrushes and this handle would update one of my older models - Revolution BR.
Edit - a lot of places are out of stock and prices vary a lot but I will treat myself :tongue-out3:
Just noticed I spelt iwata wrong right through that posting….Doh!
Edit the post and correct it? :)
This looks like a good idea, though. I might look into getting one for my HP, as I’m not all that enamoured by the cut-away rear. It seems good in theory, but if you use the set screw on the back you can’t pull the needle back to blow the brush through — which, I find, is often necessary exactly when painting things that benefit from the needle being limited in movement.
This looks very useful!
do you pull the needle through front?
It's a work of art isn't it?
I have to manage with a Fengdu Chinese copy
Miko (Iwata wannabe)
No Paul, it pulls out of the back. The silver collar on the end of the body loosens and tightens the chuck nut that holds the needle in place.
I get it but there seems to be two views about taking out the needle. I can see how the configuration works but - that needle had to be fixed in that end piece so if you were a ‘front needle extract man’ it could still be taken out of the front.
Not in this case Paul. The needle is fixed into the spring retainer with a grub screw. If you look closely you can see where this is fitted.
To be absolutely honest, I can’t actually see the advantage of withdrawing the needle from the front. You would have to undo the grub screw, disassemble the nozzle arrangement, with the needle in place, and then pull the needle through the body by gripping the finely machined tapered needle end. This seems like a recipe for damaging the needle taper to me and I can see no logical reason for doing it.
With the arrangement I’ve shown the needle can be safely withdrawn from the back in literally a couple of seconds. The nozzle arrangement can then be dismantled, and the paint path cleaned, with no danger to the needle.
As I stated in the review, the entire paint path can be made available for cleaning in about fifteen seconds using this upgrade. Being a side feed brush you do not even need to empty the paint cup to do this. You can pull the cup off, stand it in the bench, clean the paint path, and refit the cup extremely easily.
At the show I was at last weekend, two people on our stand were airbrushing with an H&S, and when one of them disassembled it, he first unscrewed the needle at the back, pulled it into the airbrush body, away from the nozzle, then unscrewed the nozzle and pushed/pulled the needled out the front.
However, he then re-assembled it by pushing the needle in from the rear, which I thought negated the principal advantage of the ability to remove it from the front — namely, that you don’t run the risk of pushing the delicate tip into something solid.
I later unscrewed the nozzle of the other guy’s H&S, and was a little dismayed to discover that if you do so, the whole front of the needle is immediately exposed and in danger of being hit by the nozzle parts you’re taking out. This because unlike the Badger and Iwata airbrushes I’m used to, H&S only has a single cap on the front, and the nozzle is essentially loose inside of that. Unscrew the cap and the nozzle comes out too.
That sounds good to me as I’m using the Eclipse now (relief). Also I can see the benefits of side cup. Damn, when I’m trying to do some detail spraying that gravity feed just gets right in the way!
I think all the fuss is about not dragging paint back through the chamber. It is a pain to take off the nozzle assembly everytime do you a quick clean - I just think wear and tear. But if you flush it through I guess it’s ok to just get the needle out the back. I just wanted to get both POV
I note that gravity feed can be a problem for detail painting due to the cup obstructing the users vision.
There are however, gravity feed airbrushes where instead of a cup on top, the bodyshell itself has a small chamber in the top of it. The drawback of course is the very small amount of paint that it will hold. Good for those doing very fine close up work on figures for example. I would imagine that this type of airbrush was initially developed for photo retouching.
Obstructed vision is why I like side feed brushes…..the cup is not in the line of sight…lthose top feed brushes with the paint cavity in the body are only good for detail work I would think. Capacity volume is around 1ml, so good luck spraying a 1/32 Lancaster with that 😁
Like I said. They were probably designed for photo retouching originally hence the very limited capacity, but fine figure work might be where they could be utilised.
As for spraying a 1/32nd scale Lancaster with one, now that would be a challenge ! LOL
Come to think about it, by ratio, one of those airbrushes would probably spray more area on a 1/32nd scale Lanc than the actual spray guns used on a full sized one !
I use an Eclipse and withdraw the needle from the front then re-insert it from the back
Before removing it I pull it back a bit before taking off the front caps and nozzle.
Always seemed the most sensible method to me, no point dragging anything back into the body.
Pushing it back in from the rear is fine, usually feel a slight resistance at the needle seal.
Upgraded my Eclipse with the Takumi trigger and a rear handle with cut out and preset.
I actually have two Eclipses, one with a 0.35 needle and the other has a 0.5.
Couldn't be bothered changing needles, now the larger one is mainly used for priming and clear coating
