Tim Marlow
The recent talk of airbrushes led me to thinking about mine. I have had it for a number of years and actually forgot i had modded it….it is an Iwatta Eclipse SBS because I personally don’t like top feed brushes, they are too clumsy for me…..but…..
I replaced the tail that came with it with this….
It is an Iwatta triple action handle. It replaces the original cut away handle and holds the needle slightly differently.
It enables me to go from that….…..to this…..
In well under 15 seconds……yes, I was sad enough to time it and I certainly wasn’t rushing
Everything that needs cleaning is accessible here. The paint path in the body is totally clear and can be bottle brushed. The nozzle, cap, paint container, and needle protector can be dropped straight into cleaning agent, and the needle can be safely wiped with a fold of tissue moistened with cleaner. This brush has no easily lost seals either….
Assembly is simply a reversal of disassembly and takes about the same time…and the nozzle is big enough to see if the carpet monsters make an appearance….
In addition to this, the handle can be set to give a preset paint delivery for things like mottle camouflage and the needle tail can be pulled clear to give a maximum quick flush while changing colours.
Ah, but how does it spray they cry…..well, it’s an Iwatta, so flawlessly is the answer…..
Here is the pack the new handle came in if anyone is interested….
Any questions, ask away as usual….
