Sorry John you can taunt me all you like I've made my mind upReally Dave I am surprised![]()
Now that really makes sense, olive oil is inert as far as I’m aware so it would do the job nicely without any issues, good shout AndrewMany years ago, someone put me onto using olive oil on the needle.....drop on a piece of kitchen towel, let it soak in and then lightly drag the needle through... Never had a problem and VERY cheap.
Also used it on a sticky trigger as I had nothing else to hand and worked a treat!!
Just a thought.
Not inert Watto, but higher in monounsaturated than other cooking oils so more resistant to oxidation. It still thickens and goes sticky over time so I’d probably not use it myself. It’s a useful finish for chopping boards though.Now that really makes sense, olive oil is inert as far as I’m aware so it would do the job nicely without any issues, good shout Andrew
Great idea, it‘ll make it easier to weather as well…..Nice one Tim, I've learnt something new again there...
From your advice the other day, I'm going to gloss clear coat my chopping board before I apply the decals
Plus one for this.I’ve used WD40 and it’s never caused a problem.
I now where you're coming from here. A bit off topic, but I sometimes put tamiya tape on my forehead, to de-tack it before use.Olive oil is a very good lube. Popeye uses it all the time. There Some one went that low. I will give myself a warning and quarantine for 5 minutes.
I have at times, back on the subject, used that wonderful 'oil' that lubricates your spec's so they slide off your nose. wonderful stuff. Great for polishing the old pipe STOP IT! I mean the brier. STOP IT I SAID STOP IT. It is also very good for the ferrule of your fishing rod to stop them getting stuck...
OK if your all just going to sit there laughing I will find something else to do.
I use that occasionally. Interesting that it seems to 'climb out' of the bottle!I think Badgers version, Regdab, works out much cheaper than the Iwata.
I don't know if it's as good but at least it's made specifically for the purpose, rather than risking something else.
Hang on, didn’t he present that Red Dwarf cookery show parody a looooong time ago? Can’t Smeg, Won’t Smeg, IIRC.
