Just got two more push/pull rods, one lever and three wires to add then i'll start adding the main pipes back on. It's been a real struggle to get these last few bits on. And i have damaged the paintwork in places. But luckily it's Vallejo Metal Color so it'll hairy stick back on with no problems. It's nice to see the contrast of the black pipes, yellow wiring and metal body. Once this bit is done then it'll be onto the combustion chambers. A couple of fuel pipes and ignition wiring to add then they'll be ready for priming and painting. Rear end of the engine just needs painting.
Oh and just for @adt70hk there are about 50 extra bits added to just this front section alone. You were saying about more than some kits you've built?
Al
That is simply outstanding. It really looks the business!! And yes that's the equivalent of two and a half Armourfast Panthers!!
Very well done indeed.
ATB.
