Hi all
Once again I am so chuffed that so many of you are following this and I'm very encouraged by your kind comments.
Now this has slowed from my usual snail's pace to a geriatric snail's pace :rolling:. That is mostly due to the complexity of the next stage - four 32 pounder cannons to go in the lower gun deck. There are 2 wooden frets for the carriages and wheels.
... and metal barrels which needed some clean up.
The barrels were primed with Stynylrez, which worked fine, and then I airbrushed them black and then gave a coat of satin varnish. The carriages went together fine and were painted Yellow Ochre. You drill holes in the carriages to fit in the gun rigging rings. I airbrushed the rings with Stynylrez and when it died it simple flaked off - God knows what metal the rings are made of. Anyway I found a tin of exterior black metal paint in the garage, left over from a metal gate I had painted. So the rings were painted with that :tongue-out3:
The trunnions have cap squares over them. The kit gives some pins which are too long and the heads are the wrong shape. Luckily I have a rivet maker so punched out styrene rivets and CAed them in place. You can see the kit pin in the photo.
Each cannon was built with a slightly different barrel angle. They have wedges fitted at the back to adjust the angle for aiming.
So after a good bit of time I now have four 32 pounders. Daft as it seems each cannon has 25 parts :thinking: Rigging them next which looks a nightmare.
As always thanks for sticking with it and all your comments and likes.
