I mentioned before that I had broken his sword, but what I didn’t say was that I’d lost it!
So I have been mulling over how to make a new one. I don't have another Scots Grey in the stash, but I could have raided my
Airfix Lifeguard kit, but then what would I do for a sword when I come to build that? I suppose I could have used a Historex one, but I was on a roll now and I decided to see if I could make one from some 6 thou(0.15mm) brass strip I had.
I held my breath and filed an edge and a point on both sides with a needle file. Then I held my breath again and scribed the blood channel – I couldn’t believe I hadn’t c*cked it up!
I had left it over length because I needed to set it into the grip, and the obvious way is how it is done in real life by narrowing the blade into a tang. Now this blade is 1.82mm wide and I need to trim away 2/3rds of it somehow. I thought of filing but I was worried about bending it, so I turned to my trusty jeweller’s saw with a 60 TPI blade(
teeth per inch for the continentals among us)
I gripped it in a pin vice and held my breath for a third time,
And then a fourth, and b*gger me, I got away with it!
I measured the tang with my digital calipers and it was 0.72mm so I used a 0.75mm bit and drilled into the sword hilt. I actually started with a 0.5mm drill and then enlarged it, just to be on the safe side, and I even got away with that!
Did I mention that I am quite pleased with this……..?
Sorry for the self-congratulatory tone of this post but I was so dreading dealing with this. I think it was this that was slowing down the progress and affecting the mojo, but now I feel like I am BACK!
Thanks for looking and the encouraging comments, it really helps
Neil
