Andy T's 1/48 Tamiya Ilyushin il-2 Sturmovik
Looks great Andy. Turning into an excellent build. The bubbly transfer could well improve with another round or two of decal solution. You probably already know this, but I’ve found pricking a couple of holes in the bubbles using a sharp scalpel helps the solution get in and the trapped air get out, so that might be worth a try.
Fantastic work so far Andy, and condolences to you and your wife.
Thank you Ian, on both counts. Much appreciated.
You're right... They don't look too bad!!! After all I cannot see the usual step in the photos!!
Interestingly, the Smythe Meister had problems with one of his long decals in his Raiden splintering!
Maybe they have cured one problem and created another lol
After snapping one of the cannon barrels off for the umpteenth time I figured I'd beef it up a bit:
The builder I mentioned earlier replaced his with hypodermic needles, but nothing so fancy here! I drilled & pinned it with some copper wire. Should hopefully be more sturdy now:
The kit MG barrels were never going to clean up well since they were about the same size as their gate, so I used wire for those too. The photo makes it look bent but it isn't. Honest guv'nor!
After a bit of detail painting and some chipping the aircraft got a coat of my favourite satin varnish from VMS. You literally hose it on then stand back in horror as it looks aweful :surprised:
However, having used it several times before I kept the faith, rigged up a dust cover and let it dry naturally to allow the product time to do its thing:
After some time we are left with this, ready for weathering:
That's really taking shape Andy.....even with all the little foibles and mishaps! Keep it coming Pardner. :thumb2:
Looks super-duper so far Andy ;)
Geoff.
Fine job Andy. Glad the decals went ok. They look good. I like VMS stuff in general but I do agree it takes a leap of faith to apply a heavy enough coat of their varnish.
Rick, Andrew, Geoff & Jim, thanks very much.
Hopefully more progress today if I can get down the wife's list. Every time I cross one thing off she adds two more! :surprised:
:smiling5:
Thanks guys!
The underside is pretty much finished now. The bay doors were an absolute beast to fit, requiring both tweezers and CA, two things I avoid as much as possible. At least they are in, and a bit of matt varnish should hide the glue that went everywhere!
I would like to have done more weathering but I just keep breaking things, so better to stop now :smiling3:
There's still a bit more work to do topside but the canopy & exhausts are now fitted.
That is looking rather excellent. Underside painting/weathering looks just as it should.
Thanks once again guys, I really appreciate your continued support :thumb2:
Looking superb andy , the weathering is spot on , just the right amount of muckying up and chipping . Painting the canopy seperate worked a treat too , the joint is totally invisible ! Fantastic work , cheers tony
She really is looking the nuts Andy.
Nick
