Annealing PE?
BattleshipBob
Cardiff
Now i know what annealing is ( not that thick, honest) but how hot and for how long??
I have a lighter but not sure?
Sorry if it seams a bit of a silly question
Ta bob
Hi Bob.
A ciggie lighter works fine for smaller bits.It just needs to get red hot for a second or two.I only anneal for curvy bits.
Jon.
For Brass I wouldn't go to Red hot to anneal.......could cause sagging or deformation......for something this thin just the color change to dull red or even less is sufficient with a quick quench. Been annealing brass cartridge cases for years......Rick H.
Many thanks Rick, very much appreciated
If you don't have a ciggy lighter ( I ditched mine when I stopped smoking 20 years ago! ) I didn't - I bought some of these
Made for lighting gas burners - you can get them at really cheap prices & are a lot more comfortable than a ciggy lighter!
Be careful that very thin parts don't overheat Bob. If you have an old PE fret you could put the part of the fret you want to anneal on top of a wide part of the old fret and heat that with your lighter.
Thanks Dave, got a ciggy lighter, never smoked lol
Thats a good idea Pete!!
JR invites Bob around for his latest PE annealing session
Cracking, not yet hot enough!
Hey Steve, That looks like my place last Saturday night.......had the kids and grand kids out for a BBQ and a Bonfire.......no joke, at least that big. burned for 2 days. :thumb2: Rick H.
Might seem obvious bob but make sure you hold the pe with pliers , it conducts heat VERY fast !
Silly question.
Why do you anneal what difference does it make.
I have been using PE for 20 years. Should I change procedures ?
Silly question.
It makes it more flexible laurie - easier to fold box shapes and drape seat belts better . Done before painting so obviously not recommended for the pre painted PE frets ( eduard Zoom etc )
It can also make some grades of brass too soft to work properly so It’s best to trial it first on scrap etch. I honestly think it’s only really of use on things like seat belts. If the brass is too soft it can make things worse rather than better....
Anything that has a regular shape or constant curve should be bent around formers. If you are likely to use a lot of etch brass in your modelling, the best investment you can probably make is a pair of high quality box jointed flat jawed pliers. Almost all of the small bends you need to make can be quickly and easily formed with them.
Thanks Tony. next Question why in 20 years has this been a secret. :tongue-out3:
Just shows how we are all different Tim. My pliers are all in a box. I use a Hold & Fold Small Shop the large mode. Expensive (tried cheap first) but sturdy & so many facilities.
Plus being vintage I find it easier to position with two (vintage) hands loose. Horses for Courses or let your friends direct your movies . :cool:
The reason why i asked is the PE seams stiff and the chap i watched on YT mentioned this so used a candle??
The thing to be aware of Bob is that annealing does make it easier to put bends in PE, but it doesn’t necessarily make it easier to put a clean bend in PE.
Annealing can also help if you've made an error! Trying to undo a poor bend can cause the material to crack ( work hardening ), annealing the bend will soften it & give you another chance...............
In my case Dave how many chances :tongue-out3:
